Problem servicing Fox Fork...help!
1 reading
5.7K views 10 replies 6 participants last post by  Muttonchops
#1 ·
Just went to change the oil and seals on my 2006 Fox F90 RL
I got the damper and oil out of that leg all fine.
I moved on to the air spring side of the fork.....when I go to remove the foot nut on the bottom of the fork, it just spins, and I can even see the air spring spinning around inside as I'm trying to remove that foot nut.
Is there a way to fix this? I obviously can't do anything until the air spring is out.
EDIT: was I supposed to keep air in the chamber before I tried to loosen that nut? (I let the air out before I did anything else)
#2 ·
Does that foot not allow you to insert a screwdriver into the slot inside the foot nut?
It should.
Screwdriver will stop the nut/shaft from spinning together.
Use a screwdriver and an open ended or box wrench and all will be good.
Yes, best to let the air out before opening up the fork+no harm done there.
#3 ·
Air in, start loosening, when you know it'll come off, then take the air out. Keep the nut loosely on, hit the nut with mullet several times and it'll dislodge.
I don't think Fox shaft/rod comes with a slot at the bottom. Therefore, Enduro website suggests make a groove in the bottom of the shaft/rod so you can hold the shaft/rod during the servicing next time... I got used to servicing it without it, although it maybe helpful when trying to install a new crush washer.
#4 ·
i've always had more success getting the foot nut off of the threaded shaft rod with 60-70 psi in the air chamber; for whatever reason, it seems to add a bit of torque resistance. same goes with reinstallation, and getting the final proper torque on the foot nut.
#5 ·
Thanks for the replies...
I havn't looked at it since earlier today, got fed up. The shaft doesn't have a groove....I guess worse case is that I dremel one in there to get it off. Will try filling it with air first though.
Will report back, thanks,
Mike
#6 ·
Worked awesome. I ended up sticking the foot nut in a vise and using a drill to get the damn shaft out, but it's out.
enduro seals and fluid shows up tomorrow and we'll go from there
Thanks for the help
Mike
#8 ·
bad mechanic said:
...what?!?
Worded that badly, oops. I couldn't get the damn thing off with a wrench and a screwdriver, so instead of loosening the nut, I decided to spin the shaft to get it off. that involved a drill with a screw bit and a vise to hold the nut, I took my time and it went pretty well.
