I Have a SR Suntour crank set. I bent the outer chain ring beyond repair while riding it. So I hope to just remove the outer crank all together. I removed the crank arm, and got to where it looked like I was going to be able to remove the desired chainring but it has these funny nuts and bolts on it. That dont look like any tool was ment to remove them. The bolts have a circle where you would use a tool to unscrew it and the nuts look like they were pressed flat. Has anybody else ran into this problem, and if so what do i need to do in order ti fix it. Any suggesting would be great thanks in advance.
