Some of the lower link surfaces are curved making it very difficult to press in the bearings. Does anyone have some tricks. Yesterday I was able to press in 3 bearings but was unable to get the last one straight and ended up ruining the link. B
Aaargh!Yesterday I was able to press in 3 bearings but was unable to get the last one straight and ended up ruining the link.
How is that able to handle curved surfaces? Any bearing press has to brace on something, and the pictures of that tool in action don't show it being used on a curved surface. Why the heck does Ibis make links without a flat surface around the bearings in the first place?I was directed to use one of these for the lowers:
I've done similar for many 'projects' over the years that require pressing in bearings (motorcycles, cars, bikes, etc). Usually, there's a way to make your own with common parts at a hardware store. Many times a socket of the correct size (OD) is part of the tool I make...you can run threaded rod through the middle of it then use washers/nuts to create the 'press'.If you don't have a decent bench vise and you can't make a tool to adapt for the curved surface then you're probably better off buying new links. I made a tool from an old BB cup to take the old pressed bearing and I use a neat-fitting threaded rod, two nuts/washers and an old bearing for pressing in the new bearings. (Can also use the vise to press the ones with non-curved shells and finish seating them with an old bearing).
Tips - If you don't get the bearings in straight at the very start, stop and reset them otherwise you'll damage the housing.
Use some assembly lube or anti-seize. It'll also help removing them next time.
Okay, so maybe I should try filing my bearing tools? How much material has to be removed?In the past I obtained rings as in the kit that I ground down to the correct shape.
I went the same route and just bought a new set of linkages. It's not worth it to screw around with pressing in new bears.I ended up buying a new link which comes with the bearings installed. Problem fixed. I know it's more expensive but the price of the link is not bad.
