PNW Loam Carbon Handlebar Review
36K views 114 replies 34 participants last post by  MTBeing
#1 ·
PNW Components has launched its first carbon handlebar, the Loam Carbon. This new 35mm handlebar is designed with comfort in mind and clearly has OneUp’s class-leading Carbon Handlebar squarely in its sights. The question is, can this newcomer unseat the best 35mm handlebar on the market?
PNW Loam Carbon Handlebar Highlights
✅ Pros:
  • Notable comfort during long descents without feeling vague
  • Third-party rated for downhill and e-bike use
  • Two rise options, 25mm and 38mm, to help riders fine-tune fit
  • PNW’s 5° of upsweep and 10° of backsweep is comfortable for long days on the trail
  • 233g weight is on par with similar carbon handlebars
  • Very competitive $149.00 price tag
❌ Cons:
  • None
💲Buy If: You want an affordable 35mm carbon handlebar that won’t hurt your hands.
Check Price at Competitive Cyclist
Better By Design
PNW used the Range Alloy Handlebar with its 10° of backsweep and 5° of upsweep as the template for the Loam Carbon. Unlike the Range, which is offered in a single 30mm rise option, the Loam Carbon comes in 25mm and 38mm rise versions. Much like carbon frames and carbon wheels, we’ve reached a place where brands use “laterally stiff, vertically compliant” lingo to peddle their latest handlebars. This isn’t necessarily a bad thing if they can deliver.
PNW put a significant amount of R&D into developing the Loam Carbon Handlebar. The Loam Carbon Bar is strong enough for e-bikes and downhill riding. According to PNW, this handlebar exceeds the Category 5 Gravity Standard established by the German third-party testing firm EFBE.
The bar is constructed from sheets of pre-preg unidirectional (UD) carbon fiber. Where OneUp uses an ovalized profile to gain vertical compliance, PNW shapes the bar from the inside, using the layup process to adjust wall thickness to damp vibration. Compliant Bore Design (CBD) is the tongue-in-cheek acronym PNW’s marketing department devised to describe the Loam’s abitly to take the edge off. So does it work?
Ride Impressions
As a lightweight rider who tests dozens of different bikes with dozens of different cockpit configurations each season, my opinion is that most 35mm handlebars ride like hot garbage. Sure, steering precision is great, but these bars transmit too much high-frequency vibration to the rider, leaving knuckles and palms aching after a few hours of aggressive riding. I can count on two fingers the number of 35mm bars I’m willing to put on my personal bikes. Could PNW make it a trifecta?
First things first, handlebar ergonomics are just as important as any tuned carbon layup. In my experience, handlebars with less sweep will put the rider in a more forward, attack position. Unfortunately, this is a hard pose to hold for multi-hour efforts. PNW’s 10° backsweep and 5° of upsweep felt very natural from the get-go. I generally like a low front end, so I tested the 25mm rise version chopped down from 800mm to my preferred 770mm width. (Riders can go as narrow as 740mm if they desire.) I used my tried and true Deity Copperhead Stem and Lockjaw Grips as controls for this test. Later, when I had a good feel for this handlebar, I swapped to PNW’s Range Stem and Loam Grips.
I was lucky enough to sneak in a late-season run down Moab’s Whole Enchilada as one of my test tracks. Of all the trails I rode, this multi-hour high-speed descent told me everything I needed to know about the Loam Carbon Bar. While I often find myself frustrated with the bone-rattling feedback from many 35mm carbon handlebars (and every integrated carbon stem-handlebar combo I’ve ever ridden), I didn’t give the Loam a second thought. From the top of Burro Pass to the last sandstone ledge on Porcupine Rim, I never needed to crack my knuckles, shake out my hands, or flex my fingers. Mission accomplished, PNW.
Is The PNW Loam Carbon Handlebar Worth It?
As I alluded to, heading into this test, there are only a couple of 35mm carbon bars I’ll willingly bolt onto my personal bikes. The first is the longstanding category leader made by OneUp. The second is somewhat of a sleeper but exceptionally comfortable, the Specialized Traverse SL. I’ll gladly add PNW’s Loam Carbon Handlebar to the list of the best 35mm carbon handlebars I’ve ridden.
In back-to-back testing, aside from the degree of sweep, I couldn’t tell these bars apart from one another—they’re comfortable and provide the level of steering precision I require. So how to decide which handlebar is best? Price and ergonomics are good places to start.
Handlebars:PNW Loam CarbonOneUp CarbonSpecialized Traverse SL
Width:800mm800mm800mm
Rise:25mm or 38mm20mm or 35mm30mm
Upsweep
Backsweep10°
Weight:233g220g (20mm rise), 225g (35mm rise)227g
Price:$149.00$159.50$170.00
Verdict
PNW has brought an impressive handlebar to market. The Loam Carbon Bar provides the steering precision mountain bikers require with a price, weight, and level of comfort that make it a clear category leader. This carbon handlebar will improve the ride quality of any mountain bike it's bolted to.
Visit PNW Components for more information.
#3 ·
The 20mm rise OneUp bar is my go-to bar (I also cut mine to 770).
Between the OneUp and PNW, major differences seem to be 5mm more rise and 2* more backweep.
Would you say you actually notice much of a fit difference between them?
In a blind test, I doubt I could tell the difference in sweep between these two bars. It's slight but noticeable when immediately switching from one to the other. After a few minutes of riding, I forgot about the 2° difference.
#5 ·
I was hoping you would say that. :ROFLMAO:
I’ll probably end up trying one next season anyway as I like to try stuff and supporting PNW is always a nice bonus.
#6 ·
I think the E13 Carbon bar also has a nice compliant ride feel. That is another one.
I think discussing steering precision is paying heed to marketing BS. I’ve tested countless bars from bone-jarring-35mm-aluminum to lovely-compliant-carbon-31.8 bars. I’ve never given a thought to steering precision or steering stiffness. Tire flex and fork twist is all I feel via that system, if anything. OneUp may have pioneered discussing steering stiffness with their unsymmetrical bars. I call BS.
#12 · (Edited)
I will buy one and try it as soon my LBS gets them.
I am prepared to be convinced but man, am I a believer in the OneUp carbon 35mm rise. I bought one late summer and was blown away. So much so that I immediately bought 2 more. My RF NextR and SixC are now on my fat bikes. They are stiff AF but who cares on the fatties? My hope is that they might not be as cold as the Norco alloy bars they are replacing.
Only gripe - the OneUp decal is already destroyed on mine.
In the PB review of the PNW, another poster made the same comment about the PNW.
I get that both come with replaceable decals in the colour of your choice, but what good is that if they are as delicate as tissue paper? I just want the plain black stock one, only more robust.
Total first world problem though. I know. It’s really the only thing I can comment negatively on with the OneUp bar.
I’m thinking that the PNW will be as good, and maybe even better with the 10 degree backsweep. Stoked to try one. I never appreciated how much difference a decent bar makes.
#15 ·
I am not sure about the Carbon, but the Alloy Range bar does not have stickers. The colors are painted on. I have the Cement Gray on my Ripley AF and the paint does not seem delicate at all.
#17 ·
Here's an idea: we buy cranks, stems, droppers, forks (travel) pre-sized. Why can't my $150 bar be factory cut to some common sizes like 780, 760? Why did I have to buy a park carbon cutting hacksaw blade and park cutting guide tool to trim my carbon bars? I mean you don't need to offer a 755mm width but c'mon give us a few factory cut options.
#20 ·
Got mine installed tonight. Good quality--feels nicer than the OneUp, close to the quality feel of the Tenet bar but maybe a touch behind (although the decals are better). Rise and sweep felt comfortable in a lap around the block, but no trail time yet. The centering and sweep markings are very good. The inner diameter seems to be a fraction smaller than my other bars; I had to knock in my bar ends with a mallet.
#25 ·
I wonder if my LBS carries these? I know they have the loam grips, which I need to try by the way.
The Loam XL grips are super comfortable.
Long term though, I found them to be too vague and when stuff got rowdy I found myself death gripping them too much to keep control of the bike.
Can’t say for sure, but they might have been part of the reason I wrecked early this season. Front wheel deflected off a hidden, leaf covered rock when I was heading down a chute to end the ride, my right hand just came right off the bar and I ate $hit, hard.
Maybe it would’ve happened no matter the grip I had installed, but I was already contemplating taking them off as I felt like there were many sketchy situations that I felt like I was struggling to keep my hands on the bars.
Ended up going back to Ergon GA2 Fat grips.
Not as comfortable when JRA, but a lot more secure when I need it and since I’m not death gripping anymore, way less arm pump.
#31 ·
Yeah I didn’t love the loam grips. They’re probably great in the wet but there’s so much siping they feel squiggly to hold.
Do both wear gloves? I wear thin, unpadded gloves, and my finger tips only need light pressure to have a really good hold on the squiggles. No death grip. Very little weight on the bars. The squiggles feel good JRA with no gloves, but I can't tell they are there with gloves on unless I think about it. They just work.
#43 · (Edited)
That is a great question! We're currently buttoning up the final layup design and running the bar through our stringent testing just like with the 35mm bar, we're hoping to have them in stock ready to go late Spring/early Summer of '24.
As for the 31.8 vs 35mm bars, in our testing we have been able to accomplish nearly the same ride quality and feel with the 35mm as with a 31.8mm version which we're very stoked about. So, if you want to pick up a pair of 35mm bars now and do not have a 35mm stem currently, we can offer up a free Range Gen 3 35mm stem as a bundle for the MTBR community while supplies of the stem last. Once the current inventory of Range Gen 3 stems is gone, and they are selling out fast, we won't be able to offer this deal further.
Please reach out to our rider support team and mention this thread in order to get the special deal on a new Loam Carbon bar and free Range Gen 3 35mm stem!
info@pnwcomponents.com
#42 ·
I love the PNW Loam Grips. I don’t how they make em so soft yet so hard wearing. I used to go through grips every couple months as I was tagging trees and I transport my bike by laying it down in the back of my SUV, wearing the ends of the grips down. But not with the Loams. I’ve had a set in my bike 2 years now, and they still look new. Can’t wait to get the carbon bar, even with them not being included on their huge end of the year sale, I’ll gladly pay full price for them.
#44 ·
Thanks for the stoke on the grips! We love to hear this feedback from riders and happy to see that you are loving them! We do apologize the bars were not on the special sale since it was a new product release. But if you pick up a bar, I think you will love them and we really appreciate the support and feedback 🤘
#51 ·
Heya. Have the one up bar waiting to go on my bike just haven’t gotten around to it.. Currently have a diety Alu bar. 38mm rise. Was a bit upset that oneup was only 35mm rise and less back sweep. I need everything I can get. Also use the diety supracush grips. Really tempted to order these pnw bars and xl grips as I still struggle with arm and hand pump ( might just be because I’m old and fat - 48 going 49.. ). Question to pnw. Where in New Zealand could I source some. International shipping is a killer and with our exchange rates these bars are probably close to double the price in my currency making them a lot more than the Oneup bars. And the return in 30 days likely not applicable given it will take 30 days to get here. :) So local might be my only option. Definitely a fan of the orange grips and bars.could see the wife liking the regular grips in pacific blue aswell. cheers
#54 ·
Sorry to hear that the shipping duties and exchange rate are not in your favor. We have worked hard to find affordable ways to ship internationally but due to us being a small company, we don't have the volume to get the best rates.
We do have two great dealers on that side of the pond and we have a dealer finder link to see if there are local shops as well with them in stock >> PNW Components
Hope you can find some to help out with that hand pump!
#53 ·
Trimmed them to my preferred 780mm width and will install them on my RS-291.
With any luck, I’ll be able to ride that bike within the next 2 weeks…
Aweseome! Hope you like them and FYI to any of the MTBR community looking for the Loam Bars. We are still offering that free stem deal and we just added the ability to cut the bars for you!!
Just reply to your order confirmation with a note on what you want them cut to right after you place the order, and we can get them cut free of charge before they ship out 🤘
