Coming May 31st, according to Pivot website. Any ideas what it is?
My old Titus Switchblade was one of my favorite bikes ever.
I that a 27.5 wheel in front and 29er on back or just my imagination.Thanks..all installed
Sent from my SM-G935V using Tapatalk
29er front and back.I that a 27.5 wheel in front and 29er on back or just my imagination.
That I just your imagination!I that a 27.5 wheel in front and 29er on back or just my imagination.
I agree for the X2, great ! For the moment, I m with the set up purposed by Fox, it s fine for the moment. I have just close lsc two clics more.First ride with the X2. Much better shock. Set up in the past for my 429A and 429C was dead easy. Set up for DPS on my 429T was more of a chore. My 429T now feels right. My SB with the DPS felt better with a spacer addition. I had a larger spacer which felt awesome on the downs but felt harsh everywhere else. A smaller spacer was a better compromise but I lost the small bump compliance my 429T has. I followed Fox's current recommendations regarding set up then tweaked per Pivot's recommendations. Riding around the neighborhood, I was worried about too much bob, but on the trail the X2 is so much better. Better mid stroke support. Better small bump compliance. High speed chop is improved although I might back off HSR a little. Efficiency feels the same which means it's pretty good, but it's no XC whip. I was worried the shock would be too complicated to set up which means I know just enough to screw things up. It's also stupid expensive and heavier. My DPS would heat up on the downs here in the summer and I wondered if performance would deteriorate out west on an extended run. The DPS is not a bad shock, it's just that the X2 is a better AM shock. I wear a hydration pack so the lost bottle space is not really an issue, but could be an issue on a long hot day.
Sent from my iPad using Tapatalk Pro
Must be something in the camera/lens. I agree with you. And look at the pedal and front and rear wheel in the second pic. Distortion much? Maybe a wide angle lens?Must be an optical illusion. I could swear the front wheel looks smaller than the rear. Maybe the angle of the picture!
I just used my galaxy s7 cell phone to take the photos. Might be camera angle as there is no wide angle option.Must be something in the camera/lens. I agree with you. And look at the pedal and front and rear wheel in the second pic. Distortion much? Maybe a wide angle lens?
I think the X2 and the DPS pedal the same.
Is that you on the Switchblade in the first video? In the orange? I noticed you have the same problem on the SB as I did and you may not realize it. It's very nose heavy when lofting it. Almost every time you jump, you land front wheel first.More Switchblade videos:
Continue to love this bike! Recently upped front travel to 160mm and it's even more beastly! Just received 2.6" Schwalbe rubber too, looking forward to mounting them up! In just over 6 weeks it's time to head to New Zealand for the Trans NZ Enduro! Weeeeeeeeee....
I'm due to post an updated build pic, I'll do so soon!
Intentionally nose bonking is not a problem, it's a pleasure.Is that you on the Switchblade in the first video? In the orange? I noticed you have the same problem on the SB as I did and you may not realize it. It's very nose heavy when lofting it. Almost every time you jump, you land front wheel first.
Solid. I'll have to check on the cost tomorrow for that upgrade. Just ordered a race XT trim today to replace my broken SB66C. Hello wagon wheels!I'd agree with this with the added bonus of being able to dial in the climbing traction even more with the X2. It's very responsive to 1 or 2 clicks of LSC/LSR, both of which will influence traction & stability on climbs. Well worth the investment if you like to have full control of your setup but the stock DPS is great for most riders. [/U]
Here are the pics. After adding stickersI love my SB but I am OCD and there is one spot that collects rocks and damages the frame. Any ideas on how to protect this area? It's located at the bottom of the wish bone near the dw link. On the demo models I noticed a lot of wear in this area and want to prevent it on mine. I have photos but don't know how to upload them.
