Coming May 31st, according to Pivot website. Any ideas what it is?
My old Titus Switchblade was one of my favorite bikes ever.
Do they make a vivid in that sizewell it "works" but it doesn't really "work"sucks to not really have other options as i didnt want to buy another fox shock but i guess the dvo goes up for sale now.
I've ridden a for a few years, like 25 or so, and I set up two new FS bikes this year, but it takes me a good 2 weeks to dial in the suspension on a bike, including finding the right pressure/preload, number of spacers, tuning compression and rebound adjustments, and so on. Someone on Ridemonkey basically said the same exact thing, about 2 weeks, so there seems to be a little commonality to this. This is usually riding at least every other day during the week and on both days on the weekends, making sure to ride in a wide variety of trail conditions and terrain, to find a good tune.I'm still a little confused how Krob and I could have found the same bikes to feel almost the opposite. This could have been setup, or it could have been an overused and undermaintained demo bike (I've had some pretty crappy impressions of bikes from demo bikes including a bike with a blown fork damper).![]()
All my close rideing buddies I know myself concluded,five total are still running the X2 with no issues two are shop mechanics and Fox authorized service center techs,both said run it just check cannister for tightness. Fox continueing procastination on a fix is more disturbing.well it "works" but it doesn't really "work"sucks to not really have other options as i didnt want to buy another fox shock but i guess the dvo goes up for sale now.
I'm still running the x2 on my sb. No problems and just over 300 miles on it.All my close rideing buddies I know myself concluded,five total are still running the X2 with no issues two are shop mechanics and Fox authorized service center techs,both said run it just check cannister for tightness. Fox continueing procastination on a fix is more disturbing.
i know but the whole thing got me concerned so i thought why not try something different.....oh well back to the x2!I'm still running the x2 on my sb. No problems and just over 300 miles on it.
Sent from my SM-G935V using Tapatalk
I will try it as soon as I have a 27.5+ wheelset. Right now all I have is 29er set.For giggles has anyone tried running a 29er in the rear and the 27.5+ in the front with the spacer installed. I'm pretty intreagued by this setup as it would raise BB height, and steepen the head angle slightly for climbing while keeping that great fat front tire. Just a thought
OMG, now I've heard it all!!For giggles has anyone tried running a 29er in the rear and the 27.5+ in the front with the spacer installed. I'm pretty intreagued by this setup as it would raise BB height, and steepen the head angle slightly for climbing while keeping that great fat front tire. Just a thought
I do have both wheelsets and have absolutely no interest in attempting it,I like slack .Worried about pedal strikes bump up front travel to 160mm,been running 27.5+ nicely without 17mm cup and very few pedal strikes.For giggles has anyone tried running a 29er in the rear and the 27.5+ in the front with the spacer installed. I'm pretty intreagued by this setup as it would raise BB height, and steepen the head angle slightly for climbing while keeping that great fat front tire. Just a thought
Hi, I Will do the same thing. You can use normal crank (PF 92), for the spindle, If you want less of 30 tooth all Will work's but you have to check the chainline. If you want more tooth, you Will probably purchase Ă spindle with 0 offset.Hi All,
I have a conundrum. I am buying a SB frame and of course the Distributor is telling me that they are not meant to be sold as a frame and it is virtually impossible to find the correct parts for it. I already have great high end parts and don't want to spend the cash(which I don't have) on a complete bike. I've sourced everything except that I've gotten conflicting info from multiple sources on the crank/spindle sizing.
Does anyone have any personal experience that they can lend so that I get the correct Crank with the correct spindle length?
Thanks All.
Just buy a Raceface Cinch Turbine crankset,reasonably priced and available now for SB.Why mess around with a make doo when you can have more chainring size choice.Hi, I Will do the same thing. You can use normal crank (PF 92), for the spindle, If you want less of 30 tooth all Will work's but you have to check the chainline. If you want more tooth, you Will probably purchase Ă spindle with 0 offset.
I Will order Ă 28 tooth, and with the Hubs of my wheels (Acros), a boost (3mm offset ) would work well and give a good chainline ; )
One question, in the blue, the other color is red or pink ? ?? Thank's
I think you can buy a different spindle length for your crank.I have already a RF next sl on my Mach 6 with 28 chainring.
I would put it on the SB, and flip the chainring if necessary or buy a boost.
I m interesting by purchasing an absolut black oval in 28 too![]()
