Coming May 31st, according to Pivot website. Any ideas what it is?
My old Titus Switchblade was one of my favorite bikes ever.
Where did you get the Mach 6 geo data from? The 2014/15 model and the 2016 model have the same geo.
I don't know whether to envy or pray for you.Ah, man, I'm back on the new E29.
Actually the published numbers did change as above. But it was obviously about how pivot decided to use a tape measure. I never saw a real explanation for it from them.Where did you get the Mach 6 geo data from? The 2014/15 model and the 2016 model have the same geo.
There is no difference between the actual bike geos from 2014/15 to 2016. Just pointing that out so folks don't think swapping between models will provided a different geo.Actually the published numbers did change as above. But it was obviously about how pivot decided to use a tape measure. I never saw a real explanation for it from them.
As already stated, those are the published numbers directly from the pivot geometry charts. Pivot must have recalibrated their measuring devices over the last 2 years.Where did you get the Mach 6 geo data from? The 2014/15 model and the 2016 model have the same geo.
When I measured my effective STA on my M6 I got the number in the revised geo chart.It's not any change in the physical dimension but rather a change in what those numbers really mean in usable amounts. The actual seat tube able is one thing that "changed" because it's more of an "effective" angle so we went with the revised numbers to give a more accurate value for comparison with other bikes... Not sure about the HA variance unless it's to reflect the stack height of the fork.
Appreciate the insight. I'm sure it's a challenge to keep with trends with loose industry standards in rapidly changing industry.It's not any change in the physical dimension but rather a change in what those numbers really mean in usable amounts. The actual seat tube able is one thing that "changed" because it's more of an "effective" angle so we went with the revised numbers to give a more accurate value for comparison with other bikes... Not sure about the HA variance unless it's to reflect the stack height of the fork.
It really is quite baffling to me how some reviewers can have such a dramatically different experience then I've had with the same machines. :skep:KRob - posted a SB review: Outerbike Test Sessions: Pivot Switchblade - Mtbr.com
I'm with you on this one totallyIt really is quite baffling to me how some reviewers can have such a dramatically different experience then I've had with the same machines. :skep:
"it (the SB) didn't feel super plush on rougher descents and didn't seem super smooth on smaller trail irregularities, an area where the Ibis Mojo 3+ really shined."
Right now a Mojo 3 sits in my garage and my wife has adopted it as her rig. I have about 300 miles on the M3 and my wife about 7 rides. We both rode the exact same route back to back on the M3 and SB in 27+ mode on the same day. To us the SB felt considerably more plush. Contrary to Krob's experience I found the SB DID seem to have the deep plush suspension feel that Krob seemed to be looking for. This is the entire reason I've decided on the SB for riding and racing - I feel like I can outrun the M3, but the SB just seems to be begging for more.
I'm still a little confused how Krob and I could have found the same bikes to feel almost the opposite. This could have been setup, or it could have been an overused and undermaintained demo bike (I've had some pretty crappy impressions of bikes from demo bikes including a bike with a blown fork damper).![]()
I'm definitely not dissing his opinion. I know we all have different tastes in what we like or want in both trails and bikes and that leads to very different desires and opinions. What's surprising is that we had the opposite interpretation of the same two machines. There's not much more to this than, "Huh, that's weird. I wonder why that happened?"Don't know why this is shocking. It's an opinion. Kent is a good rider and a good bike reviewer. But like every other human, he comes pre-programmed with his own tastes in what he likes in a bike. Just like you and me.
i've been told by pivot that that size air can doesn't work with the switchblade linkage for whatever reason. they were testing the float x for awhile and said no go. x2 or the evol can.i bought a dvo to use until the x2 issue is sorted.....used dvo but looks pretty good, rode about 25 miles the last 2 days. first days less elevation but lots of tech climbs with roots and rocks covered in leaves, shock felt OK i though maybe there was less traction but since i wasn't wide open it was hard to tell. yesterday rode my go to trail with a lot of fast downhill on all types of terrain from loose dirt to shale to some small to mid sized drop to roots, pnw riding. i hate to not like this shock as the dvo people are awesome but it just doesn't offer what the x2 does. i hit this small drop that i hit on every ride and crashed pretty hard-twice. it is about 3-4 feet into some roots, rocks and really uneven terrain. but i just got bucked off the bike and felt out of control, i have been riding long enough to know if i make an error but where the x2 absorbs and stays in control the dvo just felt weird. i went back up and ht the same line again after slowing the rebound a click to see if that was the cause and the same thing. all the way down the mountain i just felt like the bike didnt have the same control or traction as the x2 and i had a few more pedals strikes. this is with the sag set right at 30 and 4 of their volume spacers in the shock so if anything it should have more support yet it made the bike just not feel right. to me riding the dvo is more dangerous than the x2 and i really had to concentrate on keeping the rear tire on the ground verse letting it rip with the x2. it has been raining a ton but yesterday it cleared up and was warm so conditions were perfect outside of fix simply making a truly superior product i don't know what else could have been the cause....maybe this is why pivot only recommends fox???
