Coming May 31st, according to Pivot website. Any ideas what it is?
My old Titus Switchblade was one of my favorite bikes ever.
6.4 pounds medium frameWow this is a beautifully designed bike! I like the rear 157 hub with the wider flange spacing. This makes more sense than 148. It sounds like it uses a 73mm BB with slightly different offset chain rings. Am I correct in this?
Very cool bike and so versitle. I loved my past Pivots and this could become another for me.
I wonder what the frame weight is at?
I would think that would work but you could also buy the 150 air spring and change them out. Also running a 160 fork on this bike would be a good option in b+.I wonder what the opinion of Pivot would be on running a 140mm 29er fork up front with the 17mm lower cup?
I already have a nearly brand new 2016 Fox 34 140mm fork that I'd like to use if possible.
Does the frameset come with both lower headset cup options?
I just know they don't offer a 150mm version in stock form. I hope I'm wrongI was thinking it had 10mm increments in travel, no?
One solid hub for both trail and DH bikes!Here's the video link. BTW, the rear hub isn't really a new standard as you can run an existing 157mm DH hub (same as the carbon Phoenix ) OR you can build a new Boost version. The difference between the 2 hubs is simply flange spacing, both have the rotor in the same location so fitting either version isn't an issue.
The New Pivot Switchblade with Aaron Chase and Mason Bond - Pivot Cycles | Pivot Cycles | Performance Redefined
It uses a PF92 BB. That is a bottom bracket shell that is 92mm wide which matches the width of a 73mm BSA. The use of a slightly longer spindle (143mm on RF Next SL 1X), and flipping the race face ring achieves the chainline needed while maintaining a reasonable q-factorWow this is a beautifully designed bike! I like the rear 157 hub with the wider flange spacing. This makes more sense than 148. It sounds like it uses a 73mm BB with slightly different offset chain rings. Am I correct in this?
Thanks for that info. That's one of the good things about the cinch system is ability to change axle lengths.It uses a PF92 BB. That is a bottom bracket shell that is 92mm wide which matches the width of a 73mm BSA. The use of a slightly longer spindle (143mm on RF Next SL 1X), and flipping the race face ring achieves the chainline needed while maintaining a reasonable q-factor
Very similar on weight to our Followings. I'm still digging my Following and not in the market now.6.4 pounds medium frame
http://m.pinkbike.com/news/pivot-switchblade-first-look.html
I was hating on my Following for a minute because of how it was climbing. I demoed an Ibis Ripley LS and got even for hate for it. But then I dropped my MRP stage to 130mm and its like a completely new bike. So I am kinda in the market. But still going to rip my Following for now. It has been good to me for West Virginia Enduro Series racing.Very similar on weight to our Followings. I'm still digging my Following and not in the market now.
You must have longer legs/ slacker SA than me. I ride my Stage at 140 and it really climbs great for me. In high/ 140 Stage I measure my effective SA at 74+ deg and 73.5 in low setting.I was hating on my Following for a minute because of how it was climbing. I demoed an Ibis Ripley LS and got even for hate for it. But then I dropped my MRP stage to 130mm and its like a completely new bike. So I am kinda in the market. But still going to rip my Following for now. It has been good to me for West Virginia Enduro Series racing.
