Coming May 31st, according to Pivot website. Any ideas what it is?
My old Titus Switchblade was one of my favorite bikes ever.
that is awesome to hear. can you post a pic of the bike with the dw s and you on the podium, that would be nice to see! when i got my torrent and finally put the dw s on it i couldn't believe how fast i was railing a few local trails. i think that the maxis look good but being as light as they are they are cross country light and last thing i was to do is be trying to put a tube in my tire that has ripped 10 miles out......i would guess the 3.0 dw s are significantly taller than the reckons because they are so much more aggressive of a tire. how much do you weigh? on my hardtail i was 19 rear 17 front any lower and i was pushing the tire too much but i am 210 without gear.I am now running DW front and rear.I spent several days at a ride park this past weekend for an Enduro. These tires are stellar and heald up with aplomb where others were shreading tires on a particularly nasty stage.Traction is through the roof and confidence inspiring,I braked less overall and let the tires get it done. Am running 15lb front 16lb rear. I cleaned up in my class and would have podiumed in every other class except pro. Out of two hundred participants I was the only + size. Was getting heckled at first but after my results said hecklers were looking at + size with more respect and the tires got alot of attention too. Heavy yes but performance out weighs these tires overall. I do not use 17mm cup but did install a 160mm RC2 cartridge which works mint bumping up and a tad slacker, had no significant pedal strikes then usual on our very rocky trails. Am waiting for X2 coming from Pivot any day now
I'm thinking of running them in the winter as trail tires. Dirt is loamy, but rocky, some roots and more rocks. Rides down, involve fire road climbs up. Too much tire? Also, are they tall enough to remove the headset cup.I am now running DW front and rear.I spent several days at a ride park this past weekend for an Enduro. These tires are stellar and heald up with aplomb where others were shreading tires on a particularly nasty stage.Traction is through the roof and confidence inspiring,I braked less overall and let the tires get it done. Am running 15lb front 16lb rear. I cleaned up in my class and would have podiumed in every other class except pro. Out of two hundred participants I was the only + size. Was getting heckled at first but after my results said hecklers were looking at + size with more respect and the tires got alot of attention too. Heavy yes but performance out weighs these tires overall. I do not use 17mm cup but did install a 160mm RC2 cartridge which works mint bumping up and a tad slacker, had no significant pedal strikes then usual on our very rocky trails. Am waiting for X2 coming from Pivot any day now
Am not using cup no need for it,the 160mm fork raised it up enough IMO.I'm thinking of running them in the winter as trail tires. Dirt is loamy, but rocky, some roots and more rocks. Rides down, involve fire road climbs up. Too much tire? Also, are they tall enough to remove the headset cup.
Blue Mtn? I may need to put aside a second wheelset for my new bike with those tires for lift served crap. Hmm.I spent several days at a ride park this past weekend for an Enduro.
Use the chart here:upgrade to x2 for 399 is correct called pivot back today and they took care of me. if anyone has a baseline tune suggestion please post it!!
Does anyone know if pivot is offer the kashima coated dropper as an option. All I've seen is the black coated dropper. I would like kashima for a minor up charge if available to match the fork and shock.
Sent from my SM-G935V using Tapatalk
those who got the x2 from pivot, is it a 2017 with the climb switch and did they provide air volume spacers? Very glad i went with the x2 cuz i know i would have bought one full price long term![]()
2 spacers are included, 4 max can be run on that size shock.We do have the 2017 version with climb switch but it's not the full on aftermarket kit with spacers and that cool adjuster tool. I'll have to ask what volume spacers are coming in the shock (maybe matt will chime in)
if you are running this shock can you let us know what your tune is?2 spacers are included, 4 max can be run on that size shock.
Nice. I'm glad there are a few set back dropper options. Makes it easier to adjust the STA and seated TT.View attachment 1091855
I went with a Specialized Command post IRcc for the setback. Now medium sizing fits to perfection! Finishing touch the X2 when it arrives.
There is a DT cage mount. One thing I found to be very important to tire durability is rim width. IMO 50mm rims are the way to go,less chance of tire rolling over rim and pinch flating,protects sidewalls and stablizes tire .Nice. I'm glad there are a few set back dropper options. Makes it easier to adjust the STA and seated TT.
Do you have a side view of your bike I could see?
Is there a DT cage mount as well as the one in the frame?
Also ken do you have any recommended settings?
