Coming May 31st, according to Pivot website. Any ideas what it is?
My old Titus Switchblade was one of my favorite bikes ever.
Looks like a good outcome for you, good stuff! I've been running the Absolute Black oval (on my Next SL cranks) for a while on mine and it makes a real difference.Update on my woes with Race Face Next crank.
RF BB turned rough after less than 1000km, no wonder because the bearings are tiny.
Who came up with a brilliant idea of using 30mm spindle on BB92?
I replaced the BB with Rotor 4130 double row bearings and it was fine but I noticed a click on the non-driveside crank arm and no matter what I did it could be felt through the pedals.
After trying another pair of pedals, removing the chain and installing new Rotor BB, it persisted and I noticed that the non-driveside crank arm had play in the spindle and arm interface. There's also a crack in the arm from the middle of the crank arm to the spindle in the inside. I'm not sure how this came to be but I'll have the cranks warrantied.
Since Switchblade comes with super boost 157mm rear end, it's rear triangle doesn't leave a lot of room for chainring clearance and I thought that it was going to be a problem with another crankset.
Lucikly, I have great LBS so the owner ordered zero offset Absolute Black Oval chainring for SRAM GXP and installed new GXP BB along with SRAM Eagle XX1 crankset.
This setup works like a charm. Q-Factor is the same as before (168mm), but the shape of the cranks is different so while the axle is shorter on SRAM, the cranks have enough clearance to clear the chainstays without trouble.
Because of the GXP BB, I only need stock wave washer and no faffing with preload ring and spacers like on the Race Face Next crankset.
This gives much cleaner appearance, cranks are slimmer so less chance of rocks hitting them and crank arms are closer to the BB shell so there's less leverage on the bearings, and the bearings themselves are much bigger so I don't expect any problems in for at least 2 years like I did with 24mm axle on my 429 Trail.
I'm not sure if the XX1 cranks are different shape than other Eagle cranks as there were some reports that about some Eagle cranks rubbing on the chainstays with SB, but I have zero issues.
What's important to note is that you need zero offset chainring to achieve correct chainline because Next cranks come with 3mm offset ring but have longer spindle.
Here are couple of photos:
My left G4 is clicking. My left 2+ year old SixC just snapped. Going with either XT or XO1 on the SB.My left crank arm has been clicking for over a year... I'm thinking I should probably get that checked.
