Coming May 31st, according to Pivot website. Any ideas what it is?
My old Titus Switchblade was one of my favorite bikes ever.
I'm 60 years old my friend!Not for those of us one step away from ebikes[emoji12]
It doesn't lack luster. Unless it's grossly the wrong size and/or the setup is wrong.I don't understand why he said the SB lack luster in climbing. It has not sufficient traction due to upper body position.
Can someone explain it to me?
Sent from my SM-N900W8 using Tapatalk
If you are talking about my comment I think I've been pretty clear that I suspect that's due to the steep STA. I've also been pretty clear that it's a personal preference/body geo thing and not some problem with the bike. Some people love steep STAs and climb like Gods on bikes with steep STAs. So far that hasn't proven to be the case for me.I don't understand why he said the SB lack luster in climbing. It has not sufficient traction due to upper body position.
You just made too much sense for this thread.Threads that go down this path partially crack me up and partially drive me mad.
Look, I know everyone wants the bike that'll turn them into Nino Schurter on the climbs and Aaron Gwin on the descents (although, to be fair, I'd like a bike that turns me into Nino Schurter up, down, and in the gym. LOL). Unfortunately, that bike doesn't exist. Likewise, a surgically precise and turbocharged climber that's also incredibly planted descending at high-speeds and untouchable in the gnar is a pipe dream. If you think it's not, and that you've ridden that unicorn, you probably don't have a realistic idea what best-in-class climbing and descending really looks and feels like.
Hey Vik,If you are talking about my comment I think I've been pretty clear that I suspect that's due to the steep STA. I've also been pretty clear that it's a personal preference/body geo thing and not some problem with the bike. Some people love steep STAs and climb like Gods on bikes with steep STAs. So far that hasn't proven to be the case for me.
The bike is stiff and the DW-Link is efficient. I have no doubt some people find it climbs great for them.
You make a good point and one of my goals with the SB demo was to see if it would be possible to fit comfortably on a SB with either a straight or setback dropper. As long as I am able to run a slacker STA [via setback post] without any fit compromises I'm happy to try riding a steeper STA bike for a few months and see what happens.I am just saying, you might actually like the steep after you ride it more...
I think coming away unimpressed from a demo ride means it was mostly a waste of time, because you can't confidently conclude WHY the bike rode badly (unless it's a size issue, or other deal breaker). I think having a great demo ride is of value because it can give you confidence that the bike is within a certain margin or acceptability. IOW, its unlikely you'll regret buying your new bike if it really impressed you during the demo.My personal experience is that demo bikes are a complete waste of time.
Good point I guess I am just too picky about my setups. Never had a good demo ride where I was comfortable on the bike.I think coming away unimpressed from a demo ride means it was mostly a waste of time, because you can't confidently conclude WHY the bike rode badly (unless it's a size issue, or other deal breaker). I think having a great demo ride is of value because it can give you confidence that the bike is within a certain margin or acceptability. IOW, its unlikely you'll regret buying your new bike if it really impressed you during the demo.
Didn't care for the 429 Trail on my first demo ride and kinda freaked because I'd already ordered one. The second time I had a chance to demo it I changed bar, stem, and wheels/tires - fell in love.Good point I guess I am just too picky about my setups. Never had a good demo ride where I was comfortable on the bike.
Sent from my SM-G920V using Tapatalk
Some great commentary here, and interesting view points from multiple perspectives. vikb, I'm curious what other 29ers you've ridden on similar terrain, and how they compared, particularly in regard to the "lackluster climbing".
I agree that having some GPS data would be useful. If I can collect some back to back runs on the same trails in the future I will.Many of the 29ers I've ridden have felt slower on sustained climbs. At times they even feel slower descending, like on flowy or mellow sections of trail. More often than not, the slower feeling I observe when testing a 29er back to back with a smaller wheeled bike is completely blown out of the water by actual, measurable data.
The STA only matters in that it sets the range you can move the saddle around. You can't really use the all the adjustment range of most saddles. I'm 190lbs + gear so if I slam a saddle all the way forward or back it's going to break sooner rather than later.RE STA: how does this matter if you set the fore aft position of the seat so you are bio mechanically correct? For example if steep STA I probably would set my seat a bit back from the mid point. If slack STA I probably would set my seat forward of the mid point. Effective STA should be close. Confused.
Can you give an example of the types of pitches/surfaces this happened on? How steep, loose, loose over hard, smooth, rocky, etc.? It seems counter to physics at play. Generally speaking if one doesn't change riding position from level riding surface (i.e. move forward or move chest toward the bars), too much weight is placed over the rear wheel causing a light front. It's generally very difficult to move so far forward while seated to cause the rear to become unweighted. Once standing out of the saddle where our weight and CM changes much more significantly as not only our chest/torso is moving forward, but so are our hips. I can't see how you were able to weight the rear more effectively from out of the saddle unless you moved your torso back away from the bars and or your hips moved back significantly, behind the back edge of the saddle.![]()
This would be my first FS trail/AM 29er I've ever ridden. I own a 29+ Surly Krampus I bikepack on, but don't use for trail riding. Riding with camping gear is a totally different ballgame so no real comparison. This is why I am keen to try a few more 29er FS bikes to see what's just part of the 29er feel and what's bike specific.
My two normal bikes for this kind of riding are my Mach 6 and a 26er SC Nomad.
The best explanation I can give you of the difference in seated climbing between my M6 and the SB is that on the M6 my weight is right over the rear wheel [see photo above for saddle at ride height]. That loads up the rear tire and it feels like it's digging in on climbs. If I want to move my CM forward on the M6 it's easy to scooch forward on the saddle while staying seated.
On the SB it felt like my weight was further forward than on the M6 and the rear tire would more easily start to spin. Since I was at the back of the saddle already it wasn't possible to move my CM backwards without standing up.
It happened on steep dirt climb. Loose dirt over hardpacked dirt....not SoCal hardpack, but hard for BC.Can you give an example of the types of pitches/surfaces this happened on? How steep, loose, loose over hard, smooth, rocky, etc.?
I noted in my first post about the demo that I thought there was something wrong with the Fox suspension at both ends...on all three demo bikes. It was definitely not working the way I would expect. So for sure some of the traction issues could be related to that.Is it at all possible that the shock wasn't dialed in as close as you thought?
Thanks, Noah & techfersure! Tried on a 34T round ring last night and it fits.... which means a 32T Oval will be OK, just like what the both of you are running. An Absolute Black 32T ring has been ordered and can't wait for it to get here!I initially built the bike with the Aeffects and a OneUp DM Boost Oval 32t (flipped), but I bent those cranks at the Trans BC and replaced them with set of the standard XT M8000 (my only choice from the local bike shop). The biggest ring I can fit with the XTs is a 30t and I still had to put some shims on the driveside to clear the stay.
IIRC, the clearance with the OneUp DM Boost Oval 32t (flipped) was pretty minimal - so I doubt you'd have room for a 34t oval. But, it was a Boost ring, so when it was flipped it gave a slightly narrower chainline than a standard ring (Boost CL is 52mm, so flipped I reckon it was ~55mm).
Your description of the M6 is pretty bang on in my opinion. It is fairly short, especially in reach, so out of the saddle, small fore/aft movements have a significant effect. For me, it doesn't allow me enough room to move, particularly when riding aggressive downhill trails where the bike can get caught up, slowing down underneath me, and not allowing me room to move to absorb those impacts without getting too far out of the sweet spot.It happened on steep dirt climb. Loose dirt over hardpacked dirt....not SoCal hardpack, but hard for BC.
My Mach 6 front end often feels really light on climbs. We have a lot of techy climbs here and I actually quite like that feeling as the front wheel gets over tech easily and can be easily repositioned on a new line. If I want to weight the front end it's not hard as my bike is so short. I can move my weight around really easily.
Standing I can pretty easily shift my weight backwards or forwards to keep traction in the right zone and the front end adequately weighted.
The tech set the sag at 30% and I left the compression lever in wide open. We even dropped pressure between demo #1 and demo #2. I have no other experience with that generation of Fox product, but I doubt folks would accept what I was feeling.
I hope to get back up to Cumberland and grab a SB for another demo from Trail Bikes while they service my Mach 6's suspension. That will be a way more relaxed demo session where I can spend more time tweaking things to see how the changes affect my ride.
I'll run my GPS and then go back and ride the same loop with my Mach 6.
