Coming May 31st, according to Pivot website. Any ideas what it is?
My old Titus Switchblade was one of my favorite bikes ever.
Regarding wheels...Hi,
Not sure if this topic was already there at some point, but Pivot has two exotic "standards" built in the Switchblade.
Hopefully someone can answer my questions concerning these:
I guess if I destroy the crank arms, can I simply buy crank RF arms somewhere, as the independent wider RF crank axle is the "non" standard here? I am a little paranoid when it comes to non-standards and possibly travelling over longer time or to more remote areas with a bike.
(Bad experience - since then I am one of the guys who has a derailleur hanger in the backpack...)
For the wheelsets, are they available individually and do I go through Pivot? In case I want the other size 27.5+/29 additionally. What about individual prices of the DTSwiss OEM wheelsets? Are the known?
What if I want a 30mm inner width 29er rim? Conveniently possible? Are the "super boost plus" hubs available at the aftermarket and can I, re. my LBS or a wheelbuilder order them and build a custom wheelset?
I came from a Mach 6 that I loved. The Mach 6 was definitely more playful; easier to toss around in the air and pop off just about anything. But no comparison in stiffness to the SB as it loves speed and hold lines better in rocky terrain. It's also very balanced in the air so bigger tables and drops with a transition seem effortless. The 29" setup and more centered riding position also helps me clean technical climbs that I found difficult on the Mach 6. I missed a bit of the plushness at first but got it dialed for my local trails so finally sold the 6. It takes a bit more work to finess the bike through some technical sections but a bit less rebound damping in the front and rear made a huge difference in improving it's playfulness.I had to send mine back 3 times on my Mach 6 as well - ironic. They too blamed the Yoke design, not the shock. I finally demanded a new one and since then, it has been very good. Will probably go X2 on my next bike.
Not to change the subject, but it looks like there are several owners who have gone from a Mach 6 to a Switchblade. Currently looking at this bike as well as a Wreckoning, SB5.5, and a Jeffsy. Any downside to the Switchblade compared to the Mach 6. Love my bike, but I am ready for some new geometry.
Wow. I ride in rocks and my Next SLs and SixCs have held up. Are you a Clyde or are you slamming your cranks into rocks? Are you doing big drops? Light is nice, but if you ain't ridin you ain't ridin.Hi guys - I've been having issues with carbon cranks on my Switchblade. So far I've cracked 2 sets of Next SL G4's and 1 set of Sixc's.
Traditionally, I'm a big fan of Shimano cranks - xt, xtr, saint have all treated me well in the past, not to mention great bottom bracket longevity.
What options do I have that will fit the Switchblade that aren't total boat anchors as far as weight is concerned?
Thanks in advance!
Are those available in at least a 173mm q factor and along w/ a 56mm chainline? It doesn't look like the x9's are and can't find info on the e13's right off.You're probably more aggressive than most including myself. I'm an XT fan boy but SRAM X9s and BBs are pretty tough. Could always try the new E13 carbon cranks.
Sent from my iPad using Tapatalk Pro
You could Derek rig it!So if I drop 5k or so in this bike I have to jerry rig a piece of rubber down there?
