3,061 - 3,080 of 3,171 Posts
I have a brand new ethirteen trs 30.9 x 170mm dropper, mounted and ridden around my house, sold my SB with another dropper on it. Frame was a medium and I'm 5'11" and perfect with plenty more inset for a taller rider.You know many of us border line height riders went with medium frames. 210.00 shipped to states, comes complete with new cable.
How much post can you insert to an XL Switchblade? Interested in the TRS+ but it has 282 mm max inset which is a lot more than the Transfer.
We have a dropper fit guide you can use to help figure this out.
file:///C:/Users/Daniel/Downloads/Switchblade-Dropper-Fit-Guide.pdf
All of our models have some cool tech documents you can view that may help answer common questions like this.
I was hoping for a measurement value. The doc only has a line but I will measure it!
Also interesting to know if anyone has a TRS+ and it works inserted fully.
I just installed 165mm Race Face Aeffect regular boost cranks (137mm spindle) on my Switchblade and flipped the 28t chainring I was running. The chainline is fine and the Q decreased a bit but it pedals fine with way less rock strikes. I left the 17mm cup in with my 29" wheels but may stretch my fork to 160 and use the cup how it was meant with both wheel sets.
I extended my fork to 160 and switched to the 0 stack cup with 29in and it climbs better. Still descends just as well
Hey Switchblade users,
i'm new here, so hi, i'm Chris, i own a Switchblade.
My drivetrain will need replacement sooner than later, so i've been thinking about different options.
Has anyone tried to fit a 34t RaceFace chainring on the SB?
I think i've read about clearance issues.
My build is quite different from what i've seen here, so i'll try to take a picture anytime soon, to show my interpretation :)
Cheers, Chris
Has anyone else noticed this.
I've done Luftkappe conversion and extended the fork to 160mm in the process, but I've been looking at my bike and noticed that the fork legs (lowers) are not really parallel with the head tube. They actually point inward a bit.
This is even visible on Pivot's stock photos. Does it mean that the fork's steerer is not parallel with the lowers?
Maybe a bit late, but I'm running the 170mm TRS+ on a large frame. Its not 100% full inserted, but really close. No issues.
I gave my 29 SB to my brother cuz didn’t love the ride, but just rode on a 27.5 x 2.6 with 35mm IW rims and the bike was much more peppy, which is what I was looking for.
I want my bike back...
Discussion starter · #3,076 ·
It's the CENTER of the headtube that should be parallel to the fork, not necessarily the outside of the HT on the frame. Maybe the outside discrepancy is due to the tapered steerer tube?
So, here is my build.
SB XL 29"
Cane Creek Angleset -1.5°
Fox 36 RC2 140 mm
Fox DPX2
DT Swiss EX471 laced to Hope Pro 4 Evo
WTB Vigilante 2.3 and TrailBoss 2.4, both Tough and High Grip
XT Brakes 200/180 mm Rotors
RaceFace/XTR Drivetrain, the 34t Chainring clears the frame, 11-42 Cassette
BikeYoke Revive 185
RaceFace Turbine Cockpit
Renthal Glue Grips
Climbs pretty good, and is a pretty fun ride on descents.
SB XL 29"
Fox 36 RC2 140 mm
Fox DPX2
BikeYoke Revive 185
Renthal Glue Grips
Interesting, running 140mm. Stock length rear shock? Does the headset offset compensate?
Sent from my Pixel 3 XL using Tapatalk
SB XL 29"
Fox 36 RC2 140 mm
Fox DPX2
BikeYoke Revive 185
Renthal Glue Grips
Looks great and nice build. With the 1.5 degree angleset, why not use a 160 fork and get additional travel and slacker HTA? Is the BB height a concern or did you just want less travel up front?
