Coming May 31st, according to Pivot website. Any ideas what it is?
My old Titus Switchblade was one of my favorite bikes ever.
Since you nailed it, any guesses on new SB? As you know, I kinda went gaga over the FB29 (such an awesome bike) and it has the new style frame. Since the big bike has the new style frame and the baby bike (T429) has the new style frame, shouldn't the unloved, forgotten middle child get one too?I think there's room to keep the SB as the mid travel bike. If they add a long travel 29er, hopefully it will be 150-160 rear travel with 160-170 up front, and a little slacker HA. More in the realm of the M6 or FB. I see the SB as the 5.5 equivalent in the 29er category.Sent from my iPhone using Tapatalk
I can get with metric and 1x only, but, maybe it's just my svelte 225pounds, but one thing I'd never accuse Pivot of is having flexy frames.Next Switchblade blade looks bound to have metric size, sturdier rear and be single chainring only.
Interesting that you used 17mm space with 160mm fork and 29 wheelset in Florida, I never used the 17mm spacer with 160mm travel fork for both 29 an 27.5 with very little issues on pedal strikes here in rocky knar east coast Pa. Do a 27.5 plus wheelset for sure gives the SB another element of playful fun. I raced Enduros on the 27.5 plus on certain courses that were technical and rooty.So to get this clear , riders don't like the SB in the 27.5 plus mode? I'm asking because I run my SB with 29ers stock DT hubs and 2.35 HR II. With the Fox 36 set at 160mm using the 17mm cup spacer.
I'm going to build and I9 wheelset but can't decide on the plus size or building it in the 29 er and using 29x2.6 tires. I like to be able to play around and get better on jumps, I also live in FL. I just need a little input to decide... I rode the plus sizes for an hour liked it but not enough time to get the feel. Also I can not get my hands on a plus size SB to try
I did not like b+. Great drive traction in loose stuff butSo to get this clear , riders don't like the SB in the 27.5 plus mode? I'm asking because I run my SB with 29ers stock DT hubs and 2.35 HR II. With the Fox 36 set at 160mm using the 17mm cup spacer.
I was wondering why I bought the bike with plus wheels after switching over to 29 about 6 months ago. Then I rode a really really rocky trail yesterday (Gambrill near Frederick MD) and my 3.0 Plus WTB rangers and man it was great. The 36 is not the most supple fork and those big tires at low pressure took the edge off the sharp rocks. And incredible climbing up the rocky stuff. You're not going really fast on these trails where the big rubber will bend over. So I think there's a place for experimenting with Plus but i will usually run 29.So to get this clear , riders don't like the SB in the 27.5 plus mode? I'm asking because I run my SB with 29ers stock DT hubs and 2.35 HR II. With the Fox 36 set at 160mm using the 17mm cup spacer.
If you have 2017 it's worth opening the fork and setting it to 160mm. Larger negative air volume and check if there's too much grease in negative chamber.Awesome to hear stupordave! I'm about 185ish in the summer time and have been really leaning towards this acs3 for my 2016 36. I have been playing around with every pressure and setting possible for a while now, and while I dont think its bad by any means I just really expected more. Biggest issue is small bump compliance on high speed wash and roots, just feels way more harsh than I had imagined. I have 1 orange and 1 blue volume reducer in with 60 psi using almost all the travel and i'm not hucking 4ft drops. Really contemplating the acs3 and fox dpx2
Dude, I love mine in 27.5+ mode. It's way fun. I love having both wheel sets just to change things up from time to time. I run 29er more often, but when I switch back to 27+ the bike just feels more playful. The lower center of gravity, the Spiderman like traction, the extra plush ride the plus tires create. It's more fun to air it out in plus mode. Feels very jumpy with the slightly smaller diameter tires. And if I ever bend a rim, I've got another set of wheels to keep me rolling until the replacement is obtained. I'd suggest definitely extending the fork to 160. It does make the plus mode more fun in that it helps reduce the pedal strikes. If you're getting the I9 system wheels, might I suggest the turquoise hubs with dark green spokes? Looks sick AF!So to get this clear , riders don't like the SB in the 27.5 plus mode? I'm asking because I run my SB with 29ers stock DT hubs and 2.35 HR II. With the Fox 36 set at 160mm using the 17mm cup spacer.
Gambrill and the Shed are where I tested plus tires and found them too bouncy and fragile. 2.5 tires with Cushcore give the same traction with better protection and no bounce.I was wondering why I bought the bike with plus wheels after switching over to 29 about 6 months ago. Then I rode a really really rocky trail yesterday (Gambrill near Frederick MD) and my 3.0 Plus WTB rangers and man it was great. The 36 is not the most supple fork and those big tires at low pressure took the edge off the sharp rocks. And incredible climbing up the rocky stuff. You're not going really fast on these trails where the big rubber will bend over. So I think there's a place for experimenting with Plus but i will usually run 29.
Sent from my iPhone using Tapatalk Pro
I already have the fork set to 160mm...with the 17mm cup...im getting 19 hubs red with red Spank Oozy rims...staying away fro the system just case I want to rebuild into the 29er...I live in Tampa Fl...were we have technical terrain and drops ...Alafia State Park and Santos Trail head...how bad are the pedal strikes going to be? I tried a set for an hour, loved them but it wasn't enough time to make rational decision, right the reason I'm thinking of the B+ is because I want something more playfull..and our switch backs are tight. could also be the fact that I'm in my fifties its kind like having an AARP cardDude, I love mine in 27.5+ mode. It's way fun. I love having both wheel sets just to change things up from time to time. I run 29er more often, but when I switch back to 27+ the bike just feels more playful. The lower center of gravity, the Spiderman like traction, the extra plush ride the plus tires create. It's more fun to air it out in plus mode. Feels very jumpy with the slightly smaller diameter tires. And if I ever bend a rim, I've got another set of wheels to keep me rolling until the replacement is obtained. I'd suggest definitely extending the fork to 160. It does make the plus mode more fun in that it helps reduce the pedal strikes. If you're getting the I9 system wheels, might I suggest the turquoise hubs with dark green spokes? Looks sick AF!
You have to remove a spacer in the lower as well. There's a YouTube video that shows how to reduce the travel. Basically do the opposite to add travel. Here's the video.In order to change from 150 to 160 on the fox 36 is it just removing the upper airshaft and adjusting it to the next spot where it pins? Dont have to do anything in the lower? I was able to find videos on reducing travel but not adding travel.
Your dealer is incompetent and/or mistaken. As noted in earlier reply, going from 150mm to 160mm on a 2017 36 requires the removal of a spacer. You don't need a new air shaft.So I took the switchblade into a shop near me that is a pivot dealer and talked to the owner/mechanic. He said he would have to call fox and get back to me about changing the travel from 150 to 160 and mentioned I would probably have to buy a new airshaft in order to do it? Does this sound right? I was under the impression you just pull it out and adjust the current parts. It is a 2017 model fox 36. Also for those of u set at 160 do u reccomend running the 17 cup or the 0? I run the 17 currently with the 29ers and really like it. Not sure if adding 10mm of travel would make the front end too light. Really curious what the head angle would be at too?
Just search this thread for my posts...So I took the switchblade into a shop near me that is a pivot dealer and talked to the owner/mechanic. He said he would have to call fox and get back to me about changing the travel from 150 to 160 and mentioned I would probably have to buy a new airshaft in order to do it? Does this sound right? I was under the impression you just pull it out and adjust the current parts. It is a 2017 model fox 36. Also for those of u set at 160 do u reccomend running the 17 cup or the 0? I run the 17 currently with the 29ers and really like it. Not sure if adding 10mm of travel would make the front end too light. Really curious what the head angle would be at too?
