Coming May 31st, according to Pivot website. Any ideas what it is?
My old Titus Switchblade was one of my favorite bikes ever.
Nice video, thanks for sharing! [emoji4]I made another Switchblade video. This time at the National Park of Kurjenrahka, Finland.
So do you know what your seat angle is and is the BB too low now?Another modification: I put a -2 degree angleset in my 29er switchblade last week and after a couple of rides I'm really pleased with the result. The harder I was riding the bike on steep terrain the more I was getting front end tuck issues when turning aggressively. Running a 40mm stem and the 17mm cup helped but at the expense of railability.
At 5,10 on a large I was starting to contemplate up sizing to an XL but the slacker head angle has improved both climbing and front wheel grip as well as steep terrain composure.
It also "seems" to help with the forks ability to deal with trail chatter, the bike definitely rolls over chunk better with the slacker head angle so whether that is due to the fork working better at the slacker angle or my weighting the bike differently now due to the altered geometry I don't know. Whichever, I like it!
A few mates have ridden it now and all say the same thing: It's just made the bike do everything better.
The only downside is as the only member of our riding group with a headset press I now have a bunch of anglesets to fit to friends bikes!
Using the angleset to change your HTA rather than the 17mm lower cup has notably different consequences on the seat tube angle. Per my post above, the angleset results in approx. a +.4deg change to STA, while the 17mm cup would give approx. -.75deg. So a net 1.15deg difference in STA between those two approaches, sufficient I would think to notably move your weight bias toward the front and explain some of the handling characteristics you observed.Another modification: I put a -2 degree angleset in my 29er switchblade last week and after a couple of rides I'm really pleased with the result. The harder I was riding the bike on steep terrain the more I was getting front end tuck issues when turning aggressively. Running a 40mm stem and the 17mm cup helped but at the expense of railability.
can anyone else followup on this? 170mm dropper do-able on size Large switchblade?Probably a large at 5'11. Seat tube is short enough at 18 inches to run a 170mm dropper if I wanted to with my long legs (34.5 inch cycling inseam).
It's definitely doable and something I'm planning on doing soon. Seems like a lot of wasted seat post sticking up on my size large at a smidge under 6ft tall.can anyone else followup on this? 170mm dropper do-able on size Large switchblade?
Thanks for taking the time to post the figures.Using the angleset to change your HTA rather than the 17mm lower cup has notably different consequences on the seat tube angle. Per my post above, the angleset results in approx. a +.4deg change to STA, while the 17mm cup would give approx. -.75deg. So a net 1.15deg difference in STA between those two approaches, sufficient I would think to notably move your weight bias toward the front and explain some of the handling characteristics you observed.
If you didn't make any changes to stem spacers, then your front end height also dropped by a full inch, which would also move weight bias forward slightly.
After 7 months and 2,000 miles on my switchblade, I experienced my first issue with my BB-92.
I was going for an easy spin and I noticed a click when I would stand on my pedals. I immediately checked it out and noticed 1mm of lateral play in the cranks. I carefully limped home and inspected further to find that both the drive and non-drive side cranks were able to shift back and forth within the BB.
I am able to push the cranks side to side so one crank arm has a 1mm gap between the BB and the other is flushed and vice versa. Basically, the cranks may be loose within the BB, shifting the Q-factor back and forth.
Any thoughts on the problem? After only 7 months of riding, I did not expect my BB to be shot, but its looking like that's the case. Thanks for the help.
rf aeffect crankset; I pulled it apart, cleaned and regreased...There is a spacer in between the chainring and the spindle with a cup on one side of it. When I disassembled it, the cup was facing outwards when it should've been facing inwards, flush with the spindle.Are the cranks Shimano? The only time I've seen that with any of those it was due to to not getting the cranks fully into the BB when installing (the BB can be a tight fit so I use a rubber mallet to tap them fully in). It could run fine like that for a while until the seals loosen up enough for the spindle to move freely side to side. It could also be a bearing issue but I always look for the simple stuff first. 2k miles is a high number but not out of the expected life for one of those BB's
Had a trusted, young mechanic build the bike up; must have been assembled incorrectly and finally came loose. Put it back together and it runs crisp and smooth.
