I have about 5 rides on the X-Alp Launch. I normally fit a US13 and the 48 is fairly comfortable. I like the sleek thin design.
I swapped out the inserts for the D30's out of my RC's, much much better. The BOA works pretty good but most of the tightening is on the upper 2 loops. You need to work the lower laces while tightening to get lower 2 loops snug, not a deal breaker.
Toe protection is slightly above average, not quite a 2FO level, pretty much like a Freeride Pro.
I would say slightly stiffer or similar to Freeride Pro or RC Livewire. I have not run Clans.
Finally the grip. The rubber has a nice feel running long pins on a One Up Aluminum. You get a locked feel with slight amount of wiggle room. I had one slight pedal slip while casually riding and hit decent bump, this is rare on 5.10 rubber (probably my fault but I noticed it).
Hike a Bike No Bueno, pretty much like other flats that don't have some different grip in the toe area.
Too early to see how rubber holds up. Interested to see what happens in wet and colder conditions.
