New dropper post too long
30K views 17 replies 9 participants last post by  Matt164938573
#1 · (Edited)
Haven't been able to find an answer for this anywhere. Just assembled my new Diamondback Release 2. I am a newbie to dropper posts, so I was glad I got to install it to see how it works. It's a KS Lev Integra 31.6 mm. The problem is that I can't move the saddle low enough for the post to work. I put the post all the way down to the dropper joint, and yet the saddle comes up WAY too high. I'm 6'3", so that seems a little ridiculous.
Any thoughts on solutions. Thanks!
#3 ·
Dropper posts can be too long. This happens when at the fully extended length, the post can be inserted far enough into the seat tube to get the saddle at the correct height. This sounds like what you're experiencing. You need a different dropper that, between insertion depth and drop, will not be too long.
#5 ·
At 6'3" I 'd say it's unlikely a stock build's dropper is to long.
What size is is the diamond back and how much drop does the dropper have? Checking their site is doesn't list the drop. Not to state the obvious but one of the advantages of a dropper is to get full extension on climbs whereas if your used to a rigid post you may be conditioned to a much lower overall saddle height.
#8 ·
You are able to lower the post all the way to the collar?
It's possible there is a burr or something in the seat tube preventing you from inserting it all the way in the frame. Also double check to make sure it's facing forward. I see in the pics online and the bible review that the post is inserted all the way down to the collar.
#9 ·
With a dropper, one thing that needs to be factored in is the frame design...some frames are designed so the lowest possible seat position is not very low. When you extend it the height goes ridiculously high. Other frame designs, the lowest seat position is much lower so when you extend the dropper it's not as drastic. You need to figure out what works for your situation and frame design.
#11 ·
If the bike is Alu you can cut down the seat tube...
How much?
You'll have to work that out for yourself ;-)
NB, it can be done on a carbon frame also. Little bit trickier obviously.
'We'll all make it to the top... Some of us, might not make it to the bottom'
