Mongoose Malus
1 reading
6.3K views 4 replies 2 participants last post by  Canoe
#1 ·
just got the bike .... want to upgrade the gears .... can I install a 10 speed freewheel and 10 speed derailer and shifter?
I read on here that the derailer cannot be upgraded? I really want to go to a 42 gear rear and 32 front .... and the 10 speed seems like what I would want
I have no bike knowledge at all .... will upgrade the bottom and new cranks with a 32 gear ..... if I cannot go to a 10 speed would a 30 tooth front gear work?
thank you all!!
#2 ·
The Malus is in the very low end of bikes. Your upgrade choices are limited, due to the freewheel threaded hub.
https://www.sheldonbrown.com/free-k7.html
To get up to 10 rear gears you can be into some money, but it's still on a weak/cheap hub. Using a different range 7 gear or using 7 within 8 gears is common. Upgrading the hub can be done ($) so you can use cassettes, but you need one to fit the spoke count.
A triple mountain front is also used, manually switched depending on the terrain you're on (i.e., flat getting to a trail vs. out on the trail).
The Malus and Dolo are very similar.
You have a lot of reading to do.
The start of the thread is as we figure things out, but it has some common/popular upgrades listed. The middle has more experience gained. Towards the end of the thread, there's a mix of greater experience, newbies and some lost souls.
https://forums.mtbr.com/fat-bikes/dolo-semi-wild-mongoose-dolomite-902410.html
#3 ·
thank you canoe .... I read the thread and just sold the malus and buying a better brand fat tire bike .... im 63 and 300lbs and love the feel of the fat tire bike!!
im looking at a DD or a specialized ..... the DD looks better tom me?
your opinion?
#4 ·
I'm glad you gave up on trying to make the Malus do something it's not made to do. Particularly the hubs...
I don't have experience with either of those bikes, but others that do have posted here in many threads. Search. A few threads have directly addressed the need to handle higher weight riders (Clydes / Clydesdales), upgrades, riding posture, handle bars & grips, etc., to make riding comfortable so search for those too.
If you don't have the need for floating on sand, snow, etc., consider 27.5+ 4" and 29+ 3" as an alternate for 26 Fat. They came available after 26 Fat and a lot of fat riders have picked up one of the others for three-season (or year round) use (assuming Fat was for snow) and most report really enjoying it. With your weight, I'd expect either to have a better steering experience over 26 Fat, which has higher sidewalls and can result in some "self-steer". There are threads here comparing 'formats'.
Good luck!
