Mojo HDR Picture and Build Thread
198K views 656 replies 146 participants last post by  bridgestone14
#1 ·
#551 ·
#552 ·
chrisingrassia - I have to say so far I'm a fan of the DB Inline! I only have about 47 miles on it so far and no complaints. It's a bit more to set up over say the Fox... but that is also the beauty of it. As long as you don't mind taking the time, it's far more adjustable to your riding style and the terrain. If your looking for simplicity, the FoxHope that helps.
#553 · (Edited)
My HDR is just about 2 years old now. Started accumulating parts a few month's ago for an HD3 build waiting for deals and what not and just put an order in a week ago.
But I decided to take my new 2016 Fox 36 650b fork and My Derby Wide rimed 650b wheel and toss it on the HDR for grins to try it out. With the lower AtoC on the new fox fork and still running 26" in the rear the Bottom bracket did not come up that much. Only have two rides on it so far but dam I'm really digging it, 160 travel all the way around, prolly would have put off my HD3 purchase for another year if I had done this earlier.
#554 ·
14 Mojo HDR 160 w/ offset bushes 66.5 H/A
14 Fox 36 Float RC2 w/ 2 Rockshox bottomless tokens
Cane Creek Double Barrel Air CS
XTR shifters and rear mech, XT everything else 24/38, 11-36
Zee brakes w/ 203/180 icetechs
Velocity Blunt 35's on Chris king ISO, straight gauge spokes and brass proloc nipples
HRII 3C TR Front and Minion DHF 3C TR rear
125mm reverb ( soon to be a 150 LEV)
40mm easton 35 stem
santa cruz 800mm 35 bars
saint pedals
sorry for the potato pic.... my phone gets a pretty hard time. Oh yeah, this pic has a gravity 40mm stem and 760 bars
#569 ·
I run a DT Swiss spline 2 M1700 (puh, long name).
Quality DT star ratchet hubs, reasonably light (1700g) and not to expensive. If you want slightly wider and more heavy duty the e1700 is another nice choice (23 vs 25 mm).
A bit low on POE though, unless you upgrade the ratchets in the hub (easy job, but slightly pricey).
Skickat frĂĄn min E6553 via Tapatalk
#571 ·
Hey folks -
So color me stupid, but I'm not sure what's going on here. I'm turning my HDR into a stealth 650b. I've bought the new limbo chips as well as two shocks both in 7.875"x2". I'm not sure what's going on, but the distance, eye to eye, of my shock mounts are only 7.25". Neither shock fits....I've got the rear triangle all the way back, the Lopes link can't move any further (it's resting on the pedestal where it's supposed to). Did Ibis send me the wrong limbo chips? Do they look right?
#574 ·
Your rear triangle should move further back, something is up with your links I think.
You were right. Turned out my BB chain guide bracket mount wasn't installed correctly and it was juuuuuust barely getting in the way of the bottom link rotating all the way down.
Wrong limbo chips for those shocks. the bikeco shock takes the 160 chips and the travel is limited for 27.5
Actually these are the right chips. I'm not running the 147mm BikeCo shock, it's just been serviced and customized by them. Still a 130mm 2" travel shock.
#575 ·
* Frame Size & Color: Lrg Vitamin P, Cane Creek Db Inline
* Headset: Cane Creek
* Fork: Rockshox Pike 150mm
* Brakes: XT, 180mm Front, 160mm Back
* Bottom Bracket: SRAM GXP
* Cranks: SRAM XO1 GXP 32T
* Pedals: Raceface Atlas
* Front Derailleur: None
* Rear Derailleur: SRAM XO1 2.1
* Cassette: SRAM XO1 11-spd
* Stem: Thomson X4 60mm
* Handlebar: Raceface Next High Rise
* Grips: Santa Cruz Lock-on
* Seatpost: Fox DOSS Dropper 5"
* Saddle: WTB Pure Pro
* Front Tire: Hans Dampf 2.35
* Front Rim: Stan's Arch
* Front Hub: I9 Torch
* Rear Tire: Hans Dampf 2.25
* Rear Rim: Stan's Arch
* Rear Hub: I9 Torch
First ride was yesterday and I love it! Cannot believe how good it climbs. I think my only weakness in this bike will be the wheels. I can always add some later.
#582 ·
I found a too good of a deal to pass up on a 2015 monarch debonair plus shock MM tune after pretty much talking myself out of a shock upgrade.
My new HDR came with the Fox CTD shock and honsetly rode much better than I expected after reading mostly bad pub on that shock.
Is anyone using a Debonair on their HDR?
Should I be concerned with the M comp tune? Ibis specs a ML tune.
Just wondering if I should have the comp retuned or ride as is.
#583 ·
Sooooo.....my 650b setup is a total mess. Anyone else ride trails and seriously scratch the $hit up out of their swingarm? I'm running a 2.2 Trail King in the rear, and it kept sucking up rocks and squeezing them between the arc and the tire....scratching it all up. A 2.2 is pretty small as is.....do I need to go even smaller? The clearance is stupid small. =/
#585 ·
Yeah 26" tires never caused this issue for me on the HDR. Not even close. But the 650b tires are definitely a problem with clearance. I was thinking about some sticky tar/glue stuff on just that area, but it's pretty tight already. Wondering if there's some sort of hard glue that I could "paint" on there....
