461 - 480 of 1,708 Posts
Picked up my HD3 last night but won't be able to do a test run until Friday. I was amazed to see that they modified the ports for the Reverb. It looks completely factory. Here's a pic Lars sent me yesterday:
Hi, What is your Frame Size & What height are you?
I'm 1m75 (5'9") & will choose an M frame but hesitate for The RS Reverb Stealth size (125mm) : 380 or 420mm ?
What size have you choose ?
Eric
I went with the Large HD3 and I'm 5'9" with about a 32" inseam. I took the 125mm KS LEV dropper off of my medium Trek Fuel EX8. Fits very well on the Large frame. On the medium Trek, I had to have it a couple of cm above the minimum insertion to get the right saddle height.
Off hand, I would say the difference in our two builds, most of the weight difference is in the wheels (1741- Ibis vs. 1473- I9), Tires (Schwalbe Rock Razor and RaRa= 1295 vs. Bonty Xr4 =1560)- I assume you are running tubeless and frame (large vs med (.2 lb+-?). Totaled up that's a difference of 1.4 lbs. So there you go, probably not your scale.
Sweet ride u got, enjoy it...
Hi, I'm interested to install a RF Turbine SL on my futur HD3, Do you know Clinch BB compatible ? (other than RF, of course),
Eric
rotor does have a nice one. comes with the installation tool too.
Discussion starter · #480 ·
Rotor, Hope, E-13, and RF all make cinch compatible threaded bottom brackets I believe. I think the "standard" is called BSA30.
