Mojo HD3 Picture and Build Thread
416K views 1.7K replies 301 participants last post by  macduff
#1 ·
New bike means time for a new sticky thread! Here's my build, waiting on delivery of frame in December.
Frame: HD3, Large, Blue
Fork: Pike RCT3 160mm
Wheels: Chris King (red) and Derby Rims built by MikeSee (LaceMine29.com)
Tires: Schwalbe Rock Razor and Magic Mary Super Gravity
Brakes: Hope E4 Black 203F 183R
Cranks: RaceFace Next DM 32T
Rear Derailleur: XX1
Shift Lever: XX1
Cassette: XX1
Headset: Chris King I2 Red
Grips: ESI Racers Edge
Handlebars: RaceFace SixC 35
Stem: RaceFace Atlas 35
Seatpost: KS Lev Integra 150mm
Saddle: Chromag Moon
Everything but the Magic Marys (i'll run HRIIs till they come in), wheels and frame is ready to go.
What does everyone else have in the plans?
#706 · (Edited)
How are you liking the Rock razor / HR2 for SD trails?
I was running the Rock Razor all over SD and OC on my Mach 6 with no problems. I took it out to Southern Utah (think Gooseberry) and it wouldn't hook up at all. Ended up pulling it off and throwing on a 2.4 Conti Mountain King which worked out great and continues to impress on climbs back in SD.
#700 ·
I am looking to run mine internal as well, but I do not run my brakes "moto style" like digihippie. I was thinking (while waiting forever for my frame) of not crossing the head tube at all. Has anyone run the dropper from the left side of the bars into the port on the left side, then run both the rear deraileur and rear brake into the double port on the right side straight from the right side of the bars?
regeniac ran his rear deraileur the way I am talking about (see below). I am open to thoughts and opinions...
Kinda like this mockup I did on a tranny:
#710 ·
Kicking the ideal around of getting one of these new Fox Forks for my HD3 Build, so I can play around with running 27.5+ tires on it.
Mountain Bike Action Magazine | Fox Launches New Fat Bike Fork For 2016!
The all-new FACTORY Series 34 FLOAT 27.5+was designed from the ground up to be extra-wide rim and tire ready.
Features and Benefits
• Chassis designed specifically for 27.5+ wheels and tires
• 15QRx110mm wide-flange hub spacing
• 4th generation FIT4 closed cartridge damper
• New FLOAT air spring
• Clearance for super-wide rims
• Supports tire sizes up to 27.5"x3.25"
• 51mm offset
• Travel range 110mm to 150mm
#712 ·
I'm still a little confused about this 27.5+ so please go easy on me. but if you decide to go with a uber wide tire in the rear, I don't know if there enough clearance on our bikes.
My understanding is you put a uber wide rim with a gigantic tire? So are you just going to do that setup up front with this new fork?
#713 ·
I just noticed it using a new hub "Standard" so my interest just waned, why not use 110x20? a standard that already exists, guess that would be to easy. I did use bigger endcaps and an offset brake adapter in order to run my fat bike 135mm hubs on a Bluto fork with 150mm spacing, so maybe we will see the after market come out with some of that stuff.
Does look like the 2015 Fox 36 technology is trickling down to the 34 platform for 2016 and should probably be available in May.
#718 ·
Damn you m1sha! One day before my bike was finished! I wanted that vital bike check of the day! I guess I'll have to console myself by going out for a ride!!! Here's my build just need match pike decals and I'll be set. Here's some cheap cell phone pics. Thanks to Fanatik bikes for the sweet build and service!!
Xl Green Frame
160 Pike
DB Inline
Xo1 shifters
Xo1 derauiler
X1 cassette
Sixc cranks
Sixc bars
Atlas stem Tommy
Guide rsc brakes
Reverb 150mm
CK headset
Ibis 741 wheels with i9 hubs!
Silverado Pro saddle
2.3 dhf front tire
2.25 ardent rear
