1,861 - 1,880 of 2,375 Posts
How were you able to put your remote for the reverb like that? I also have a left hand remote but mine is on top and trying to figure it how I can make it just like yours.
It's right-hand remote mounted upside down. I'm afraid that you will have to swap the remote to have it under the bar...
Dang it! I should have gotten the right hand remote then. That is why I'm having a hard time mounting it like yours. It would be easier to press mounted that way. Thanks, though.
Loving the HD with Wetscreams. They can be one of the most fun tires you can ever put on a bike when the conditions allow.
I used to laugh all the way down some tracks at the insane levels of traction that I had no right to have
eidited for stooopid tiipos
Third year with the Mojo HD. Still blown away by how much fun it is to ride, and such a timeless design too. Pic snapped during a Summer night ride.
I've been following your blog for some time now and I just wanna say that's its awesome!
Sweet mojo btw, how's the zee rear mech treating you?
Hi,
I'm not sure what do you mean, I don't have a Fox RC4 shock, but I do have a Marzocchi 55 RC3 fork:)
On the fork, I'm still fine adjusting, but right now I'm at 30 clicks of preload, no air, 9 clicks of rebound and 6 clicks of compression (clicks from full open). I'm ± 85kg (185lbs) geared up.
Cheers.
p.
Sorry, I should have looked more carefully. What settings on your Vivid. Presume fairly open compression and rebound? Just curious as I have a CCDBA and an rc4 which I'm tempted to put on for comparative purposes.
Cheers
Matt
Ok, without further ado, here is the component list, just waiting on a few items to arrive by mail but everything else is GTG...
Size:.........Medium black with blue linkage
Fork:.........2013 Fox Float 36, 160mm
Shock:......Fox RP23 (Stock)
Wheelset:..Easton Havoc, grey/white/black
Headset:....Chris King lower Cane Creek upper.
Handlebar: Easton Havoc Carbon, will prob cut to about 710mm
Stem:........Chromag Ranger 50mm, blue (to match linkage)
Brakes:......XT with 160mm ice-tech rotors front and rear
Grips:........ODI rogue lock on, black.
Shifters:.....XT I-Spec 2x10
Front Der:..XT direct mount 2x10
Rear Der:...XTR Shadow M-986
Crank:.......XT 2x10, black @175mm
Cassette:...XT 11-36
Chain:.......XTR dyna-sys 114 links
Seatpost:...Rock Shox Reverb dropper
Saddle:.....Chromag trailmaster DT, white to match fork.
Tires:........Schwalbe Hans Dampf 26 x 2.35
Pedals:.....XT trail with wide platform
Will post pics when she's done!! :thumbsup:
Frame:..... Large, White
Fork:.........BOS Deville 160mm Tapered
Shock:......BOS Vip'R special setting for Mojo HD
Wheelset:..Asterion wheels (rims ZTR Arch EX, Hub asterion by Aivee, handbuild in France)
Headset:....Works Components -1°
Handlebar: Renthal Fatbar (cut at 750mm)
Stem:........Renthal Strata
Brakes:......Shimano XTR 180/160
Grips:........SB3
Shifters:.....XTR 1*10
Front Der:..E13 XCX+
Rear Der:...XTR Shadow +
Crank:.......XTR with Renthal 36
Cassette:..XX 11/36
Chain:.......Shimano XTR
Seatpost:..KS LEV 150mm
Saddle:.....Fizik Thundra 2 White
Tires:........MAXXIS High Roller 2 2.40 (3C EXO 2ply) , MAXXIS Larsen 2.35(2 Ply , downhill)
Pedals:.....XTR
Weight:.....13,6kg 29pd
it looks even better than your earlier post, i like the fatbar and renthal stem, are they a good colour match for the bos stanchions? i've got some easton carbon bars but like the bars match fork look
I don't think it match very well with the fork , but it's very rigid, strong but not heavy. I had a Eston Haven Carbon 2 years ago, and after one season it look like a chewing gum and make some noise. now I want something strong.
The new whip is finally finished! I took her up to Solstice in Fairfax for her maiden voyage.
The bottom line: This thing freaking rips uphill and downhill!!! I couldn't be happier! :thumbsup:
Frame: Ibis Mojo HD 160 with Kashima Fox Float CTD
Fork: Kashima Fox Talas 36 RC2 180-140
Wheels: Mavic Crossmax ST
Tires: WTB Bronson UST 2.3
Cranks: Sram X9, 2x10, 26/39
Guide/Bash: MRP 2X
Front derailleur: Sram X0
Rear Derailleur: Sram X9
Triggers: Sram X0
Brakes: Hope Tech M4, 203 front/160 rear
Bars: Chromag Fubar OSX
Stem: Easton Havoc
Grips: Odi Rufian
Saddle: T.H.E. Icon
Post: Fox D.O.S.S. 5 inch
Headset: King
Pedals: Shimano XT
Casette: Shimano XTR
Chain: KMC
Looks like you're totally sold to FOX ;)
So what about this seatpost & ugly (my opinion) command ?
Sram xx1
Hello Maverick,
Nice rig, I am going to order a sram xx1 group for my Ibis HD 160mm, but firts I would like to be sure about the size of the cranks GXP Q156 or Q168, and also if the frame needs a modification to install the group (Based on your experience)?
Thank you for your attention and time, waiting for your reply.
Regards,
Carlos Vélez
Here she is definitley worth the wait, thanx to my awesome LBS/ for getting her together for me today, wouldnt let me leave lol and also to our importer who was also awesome, cheers guys.
Frame: IBIS Mojo HD Large
Colour & Mode: Vitamin P red links /140mm flip chips
Headset: Chris King inset Red
Fork: Fox 34 Float ctd Kashima set @ 150mm
Shock: Fox Ctd Kashima
Bar: Chromag OSX
Stem: Chromag Ranger black 50mm
Grips: Odi TLD
Seatpost: RockShox Reverb dropper post
Seat: SDG Duster green (temp one on at mo only blem till in stock)
Shifters: Sram XX1 rear
Cranks: Sram XX1 175mm carbon
Chain ring: Sram XX1 34t
Chain: Sram XX1 11spd
Cassette: Sram XX1 9/42 t
Rear D: Sram XX1
Brakes: Avid Trail XO 180/180
Wheels: Enve's /Chris King 15mm front 32h / rear DT 240s, 142x12
XX1 XD driver hub shell
Tires: Maxxis
Front Maxxis Ardent 2.25, rear Maxxis Icon 2.2 exc/exo I run tubes, maxxis superlight 0.87mm Presta valves.
Pedals: Crank Bros Mallet 3s
Also thanx to Hans for putting up with my pms
but I do appreciate the replies gave me lots of confidence to hang in there and wait.
