Well I finally had a chance to get out on the HD650b, and although there is still some fiddling to do with suspension setup, this thing felt great!
[/URL]
This was a brilliant chance to work out the differences just a wheel and fork change can make going from 26" to 27.5". I ran the same spec tyres (2.3 HR2 front, Ardent 2.25" rear) which also helped. Although I dropped a decent amount of weight from its previous 170/160 coil setup, its essentially now sitting at the same weight as it was in HD140 guise, the way I rode it for the majority of its life.
Anyway below are some interesting observations...
Parts changed:
Fork - from a 2012 150mm Revelation RLT Ti 20mm maxle (or a 170mm Marzocchi 66RCX 20mm thru axle) to a 150mm Pike RCT3 Solo Air 15mm maxle lite.
Wheels - from 26" Easton Haven to 27.5" LightBicycle 35mm ext (30mm int) AM carbon rims on DT Swiss 350's (with 36t star ratchet upgrade).
Tyres - HR2 2.3 fr, Ardent 2.25 rr (same tyres just different dia.).
Clearance:
This it's an easy one - no clearance issues! Remember this is just a fork and wheel change, no other geometry was (yet) harmed in the making of this 6-fiddie... The guys at Ibis say it works set as a HD140 wothout any mods, and it's the thruth.
Clearance on bottom out as posted previously... (with OEM HD140 limbo chips and shock)
Acceleration:
Due to the lighter wheelset (1480g vs 1650g) it was always going to accelerate a bit better, and it does! Physics may suggest that the larger wheel should slow it down in this department, but I guess wheel weight trumps wheel size in this case! Out of corners in particular I noticed the added acceleration. Combined with the lighter feeling front end it seemed to pop out of corners better than ever before! (heavier fork + lighter wheel seems to feel lighter than a lighter fork + heavier wheel of equivalent weight... If that makes sense? Makes sense from a physics perspective, lever arm/moment/etc).
Cornering:
On entry into and through the corner I could definitely feel additional grip. The salesmen are right! ?? Of course, my rims are quite a bit wider so that could have attributed to the added grip as well, along with added stiffness of the wheels. One drawback I felt from this conversion was the higher BB. From memory mine measures bang on 14" static, so I was running a little more sag to compensate. It wasn't a deal breaker by any means, but it was there in the flatter corners. I had always planned on installing offset bushings to counter this (along with shortening the travel slightly, making it essentially an HDR), but wanted to test the bike first beforehand. Turns out, yep I prefer a lower BB. The added pedal clearance was however a bonus on a trail with lots of little rocky pedal snags. I could just motor through sections that I would have normally had to time my pedal stokes.
Change of direction/playfulness/jumping:
Wow! This was something I was a little worried about as I find the HD a very playful bike, its why I'm still riding it over 4 years later. I guess this all comes down to wheel weight, but the bike felt more playful than previous! Even jumping felt more comfortable, and that's coming from someone who tends to prefer keeping pretty close to terra firma.
Climbing:
Better through the rough climbs, no real disadvantage on smooth climbs. Not much else to say but win win!
All in all, stoked! It should only get better from here with the Corset can to go in along with offset bushes! ?
Cheers
*3o3
