A long time ago in a galaxy, far far away ... I felt a disturbance in the force. An unknown craft, the thicc Drunken Rhinoceros, was imminent to land on Fatooine.
I knew right away this wouldn't fit in my existing ride.
Also, how could I justify investing in yet another fatbike? The carbon 'Saw on 4.6" tires and 85 mm rims is a phenomenally versatile and light machine. I kept convincing myself that the lack of float could easily be offset by the steep terrain. And the Alps have plenty of it.
Pick your line. Literally.
Still, the Drunk Rhinos kept me thinking. By my crude calculations, it could be as much as 15 % more volume compared to 105 mm rims, making the jump to a new platform feasible. A New Hope ... or an expensith experiment? One way to find out.
Didn't even last a month I gave in. You never know how many winters you have left.
A simple web form question about the chainstay clearance was met by a quick reply from Markku (Pässilä CEO). 49 emails later with a few exchanged CAD drawings, the redesigned titanium prototype arrived. After trying countless leads, I couldn't believe it myself: there's a company in the bike industry willing to consider my ideas and run the thing. There are a few people, Mike including, that helped make this happen. You have a special place in my heart.
Meet the Pässilä Roteva.
For some, the build might be unorthodox. This tire-rim combo with a Mastodon. Certain geometry choices. 24/50 granny gear. Aenomaly Switchgrade. 225/200 mm discs. All while trying to keep the weight reasonable (16 kg / 37.5 lbs with Johnny 5 spikes, slightly more with Vee 2XL tires).
My personal opinion (or theory, if you want) is that the bike industry, in general, hasn't come even close to realizing the full potential of the fatbikes. This goes doubly so in the Alps which offer spectacular terrain, especially in winter. Far from groomed trails or ski pistes, there are worlds to explore.
Often, with plenty of altitude, which means rapidly changing conditions and snow consistency from the trailhead to the summit. Therefore, component versatility and adapting to the environment help a lot. You can encounter dry trails, hikers' post holes, icy patches, hard crust, fresh snow, etc. all in one ride.
Ideally, that bike would be full suspension for bumpy sections, extra traction, and comfort, but one can dream. Key specs:
For those still reading, you might be wondering about the first ride impressions?
It ... floats!
It can also enter hyperdrive if you screw it up.
Well. I might be too excited and biased for a proper ride report. Also, it wouldn't be fair to steal the spotlight from Master Yoda before he tries his creation too, and can provide detailed feedback and comparisons with 105 mm rims.
I'll just sum it up with a quote from one of my best friends:
- Geometry per their website, with a wider and slightly longer rear end. Having tried their AM hardtail with a 78º seat angle, I long for an even steeper seat angle for a better climbing position on steep terrain.
- Frame is pretty light, 2125 grams for S4 size. With enough clearance to (barely) run the widest combo, Snowshoe 2XL on 128 mm rims.
- Wheels: Nextie Drunken Rhinoceros 128 mm rims. Opted for matte finish for aesthetics. Might try coatings for less snow build-up if needed. CX-Ray spokes, tied and soldered for extra stiffness/strength, Polyax brass secure-lock nipples. DT hubs w/ 54T upgrade. A pair of XL studded Johnny 5 for extra grip when the snow transforms into firm and icy.
- Mastodon with an IRT upgrade will do for now. Amazingly, it has enough clearance.
- 24/50 granny gear is juuust enough for slow-speed grinding. Planning a custom steel 22T or 20T RaceFace Cinch direct-mount.
- The chainline and cassette needed some tweaks to clear the 2XL tire (not needed for Johnny 5): RF 24T flipped outwards. Removed a few cogs from the Sunrace MX80 11-speed cassette, and combined it with Shimano 21-24T cogs. The whole cassette is down to 8 cogs. This way there's ~11 mm offset. Fill the gap with Shimano BB or other suitable spacers on the freehub. Sram GX will need a longer low-gear limit bolt.
- RF Next SL cranks on 190 mm spindle and enclosed Hope BB spacers. This clears the chainstays with ~5 mm with a reasonable "internal" Q-factor of 195 mm (distance between the inner part of the crank arms).
- Aenomaly Switchgrade needs no intro. I've been using a crude DIY version for years and find such a mechanism indispensable on all my bikes. Paired with OneUp 240 mm dropper, it's a fantastic combo.
- Previous gen XTR brakes with a special sauce to solve Shimano brake point wandering problem - Bleedkit.com Gold Oil. A carbon lever blade for less cold transfer and a shiny one-piece caliper. Trickstuff Piccola Carbon HD also has carbon levers but is "a bit" above my pay grade.
- 225/200 mm discs. There's lots of rear wheel mass to stop, especially on long descents.
- Syntace Numbernine flats for light weight, good grip, and zero snow build-up. Their Megaforce 30 mm stem and 800 mm Newmen bars surprisingly don't feel too wide (yet?).
- Last but not least, Cane Creek Viscoset. I need to fine-tune it and increase the damping, but the first impressions are extremely positive.
It ... floats!
"Money well spent."
