Maxxis Aspen 29x2.40wt
22K views 17 replies 11 participants last post by  Hrodulf
#1 ·
This year I have been riding Maxxis Aspen 29x2.40wt on DT Swiss i30 hookless carbon rims front and rear on Trek Top fuel 2020 bike.
1.11bar/16.1psi front, 1.25/18.1psi rear. Rider weight 68kg.
I really like them and there seems to be many other riders who like them as well. Very nice tire for xc/light trail.
For me,
Positives:
-Low rolling resistance.
-Ability to ride lowish pressure without "squirming".
-True to size (2.42"/61.5mm) at 18psi.
-Low weight for fat xc tire (720g).
-Predictable grip on most surfaces.
-Easy to install tubeless.
Neutrals:
-Durability/Longetivity. I have had 3 punctures this summer. Central knobs seem to wear pretty quick. Overall fine durability but maybe not the best.
Negatives:
-Front cornering grip on looser surfaces not the best.
Overall I am so happy with aspen 2.40wt that I won't be checking any other tires soon.
How do you feel about Aspen 2.40wt?
Thanks.
#2 ·
Did you run the EXO or regular version, given the weight of 720g?
I'm currently riding the new Fast Trak's 29x2.35 T5, coming from Aspen's 29x2.25 EXO. I was quite surprised how much grip the Fast Trak's provide during cornering, and the suppleness of the tire as well, excellent self- damping.
#5 ·
My feedback on the Aspen 2.4 in the XC Race Tire thread. Had my 2nd ride this weekend on hardpack soil with bit of sand and just crushed PRs left and right.
Love the 2.25 Aspens but the 2.4 just adds that little extra volume im not beat up.
After a very wet July and part of August things finally drying up for good September races in New England. Swapped to 2.4 Aspen front and rear. Both tires pretty close to factory weight spec (717g, 722g). When mounted looked very small, but after one ride tires measuring right at 2.4. The volume is pretty amazing, very supple ride. Really bring the pressure down versus my prior race setup (AR 2.35/Ikon 2.25) to 23psi front/26psi rear.
First impressions of shakedown ride (trail mix of fireroad, hard to medium loose singletrack, lots of small rocks). Avg pace: 11.1mph
Pretty wild such small knobs do the job but felt pretty comfortable loading pretty good into corners. More feedback and not muted like my AR.
There was some greasy rocks and expected to slide but nope, held its line. Better than the Ikon but not as good as the AR.
Acceleration with larger tire felt OK, Ikons much better initial bite and power transfer. But once your moving at a good clip, Aspens just had crazy momentum. Saw this during the fireroad sections, soft pedaling and holding good pace.
#11 ·
Most of the Maxxis sponsored Athletes run the 2.4 Aspen (or Aspen ST). I ran one last fall for a few weeks as a rear tire. Overall I was very impressed with it. Then I punctured it on a seedpod because there is no treed to protect the tire. I went back to my Mezcal and never had any issue.
I can't say the Aspen "feels" faster than the Mezcal. I am curious about Rekon Race 2.4wt.
But I have had such a good experience with continental cross king front and Mezcal rear that I am not sure it's worth it.
The extra volume for a hardtail is what's pushing me to try them.
#12 ·
I do have experience with the Rekon Race and it is a mighty fast tire, pretty versatile too. At least more versatile than you think, based on the tread. Pretty reliable as well. I think because of the smaller knobs are closer to each other compared with the Aspen.
#14 · (Edited)
I don't get a long with Schwable XC tires. They (Ray / Ralph) felt slow, had no grip, weren't particularly light and started shedding knobs on my first ride. And I got them in the super ground casing.
I have much better luck with Schwable trail tires (nobby nic is great!)
I have no complaints with my Crossking / Mezcal combo (it's tough and fast).
I just like trying new tires.
The thunder burt does look like it will be sweet.
#15 ·
I have extensively rode the Thunder Burt (Fr/R) this summer... and what a ride !
Grip and traction way more than you should expect from such a tire. Especially cornering grip is great. No dead or vague zones in the tread - very predictable. Even in the wet (as in no mud) it is holding up. Very reliable and slow wear. And fast !! As in fast.
Can't think of anything negative of the Thunder Burt. And I am a Maxxis guy, typically I don't like Schwalbe tires. But the Thunder Burt is a class on it own. That being said, the Rekon Race is not bad either, absolutely not. But the Thunder Burt does everything just slightly better. Hence my question about the Aspen 2.4, to understand if it would be on par with the Thunder Burt, but hearing you guys the performance of the Aspen is not even better than the Rekon Race.
#17 ·
I've just installed an Aspen 2.4" on the rear in place of Rekon Race. I'm pretty nervous about puncture resistance, but the volume is fantastic.
I've always been a huge Schwalbe fan and the Ralph has been my rear tyre almost exclusively for over a decade. The availability recently, and Schwalbe measuring slightly smaller/not available in 2.4" has lead me to trying some other tyres.
I'll report back if there's either a speed difference or something unforseen happens with the Aspen.
#18 ·
I have also ordered a 2.4 Aspen for on the rear, which I will pair with a 2.4 Ardent up front.
If the Aspen will succeed the test, I will throw one up front as well, for once spring arrives here.
Fingers crossed that they will measure about the same in width... the Ardent is just a hair under 2.4 on 27mm rims, though will grow for sure since I have just rode about 127kms/80miles on it.
