Purposely posting here, not in wheels and tires, but maybe it'll become a sticky somewhere.
This question seems to be forever recurring.
In the past, it seemed that if your internal rim width in cm = your tire width in inches, you were fine.
Example:
2.1" tire works great on a 2.1cm (21mm) internal rim.
2.5" tires works great on a 25mm rim.
But then you get to 2.8 or 3.0 and it seems to fall apart. It might even be a weak argument at 2.5".
If you go really big, it's nearly a factor of 2: 4.8" tire needs at least ~80mm (to 100mm rim). Granted, this is a different animal.
I think what everyone wants to read is a guideline.
This, I think, is questionable:
https://www.dtswiss.com/Technology/MTB-rim-width
Check this out too: https://www.dtswiss.com/Resources/Tech-PDF/Tire_Pressure_Dimension.pdf
I think I would have a much narrower interpretation.
Shall I say, debatable.
I know the "rules" aren't hard and fast, but some guidelines maybe for the newbs?
21mm rim = 2.1" max tire
25mm rim = 2.5" max tire
30mm rim = 2.8" max tire
32mm rim = 3.0" max tire
35mm rim = 3.25" max tire
or is it more like
45mm rim = 3.25" max tire
-F
Example:
or is it more like
-F
