Edit: yes, the Mara Pro does exist
Since it was first spied at Sea Otter, the Mara Pro has been slow to come to market, even the Manitou website hasn't linked in a set up "schedule"; come on already!
I'd been riding a DPX2 and a tuned Bomber CR Coil on a 140mm travel GG Shred Dog. The Bomber felt dead no matter how it was tuned. I preferred the DPX2 for overall ride quality, but it tended to bottom out easily when run soft enough for small hits.
When I upgraded to a GG Megatrail, I needed a new shock, and since I had just ordered a Mezzer, it was only natural to get a Mara Pro
I have a few rides now on the Mara Pro 230 x 65. Set up was easy, though I had to peruse Pinkbike and various other sites to get a sense for what some folks had run; hey Manitou, where's the set up guide?! I was able to quickly settle on a pressure that felt good on small hits, but didn't lead to excessive bottom out.
I'm 190# plus kit, aggressive "older" rider
Guerrilla Gravity Megatrail 155mm in Trail Mode, suspension design is reportedly "digressive".
125psi (Lezyne Shock Drive)
HSC 1
LSC 14
R 6
Party mode all the days
Work Mode: Not just another lock out.
So the work mode doesn't actually lock the shock out, but instead seems to provide a second damper setting, which is pretty cool if it works out that way. What I'm working on now is trying to sync the "work mode" on the Mara Pro to an equivalent setting on the Mezzer, TBD.
Overall I find the Mara to be very supple, absorbs the small hits without being boggy, takes the big hits and g outs with bottoming out, pretty much set it and forget it. The Mara does have a big reservoir, so make sure you have room for it.
I got mine for $475 pus tax with a discount code.
HSC 1
LSC 14
R 6
