I'm currently in the market for a new bike as I detailed in a post earlier in the week. I've recently started riding more aggressive trails and my current bike isn't really setup for them. I currently have an aluminum Niner EMD 9 with 100mm travel, aluminum bar, 2.35 front tire and 2.25 rear tire on 23 inner diameter rims. I was debating between getting a more aggressive hardtail or a full suspension. I feel as though a more aggressive hardtail with more travel and a dropper would be a vast improvement over my current bike on the steep declines, but if I choose to go with another hardtail I'd like to find something that is a lot more comfortable over the long rock and root sections where I seem to take a beating currently. I love the simplicity and low maintenance of a hardtail but my ride quality will need to improve substantially to consider one over a full suspension.
I'm looking for some feedback on a number of items in terms of how they would help create a smoother ride:
Chromoly vs Aluminum Frame
I've heard chromoly frames ride substantially smoother than aluminum frames, but haven't ridden one personally. Is there any truth to this? If I go the hardtail route I'd be looking to build up a frame. If chromoly is a way smoother ride I'd likely be looking at the RSD Middle Child and if I went aluminum I'd likely go with a Nukeproof Scout.
29 vs 27.5+
I'd likely be looking to run a 2.5 or 2.6 tire on a 29er setup and a 2.8 on a 27.5+ setup and would ensure the rim would be wide enough to fit the tires properly. I've only ever ridden a 29er so I have no idea if there would be any difference in comfort. What would be the better option? My current 29er is a beast on non-technical climbs and doesn't have much trouble getting up steep rock faces and I wouldn't want to sacrifice this if the 27.5+ wouldn't be as good.
Components
I've heard a carbon bar can make for a much smoother ride than an aluminum bar. In addition to this are there any other component selections that I should be considering?
I'm basically trying to figure out if I build a new hardtail factoring in everything above will it be a vast improvement on my current Niner through long rough sections or is my best bet to keep the Niner for XC trails and pick up a full suspension for more aggressive trails.
29 vs 27.5+
Components
