Hi all, I've owned and ridden a Pivot Les Fat since 2015 and I've been through 7 Bottom Brackets in that time, and now ready for an 8th. This is a 2nd/3rd bike so it does not get a lot of miles, but I'm regularly cleaning and checking items like BB when it gets used. According to Strava data, this bike has 2500 miles on it, so 7 bottom bracket replacements is pretty shitty.
Part of the problem was the choice of using a carbon press fit BB Shell for a bearing system that was intended for 24mm spindles, and opening that up to 30mm with the same 41mm OD for bearing shells. This makes for a skimpy bearing size. Originally, these bikes came with a single row bearing BB and that lasted about 2 months. When I went back to Pivot and E13 about this, they said they recognized the problem and had found a dual row bearing solution. I brought my bike down to E13 since they are fairly local to me and they fitted the newly designed BB. I got 6 months out of this one. Improvement, but not really acceptable. Since then, I've just continued to replace BB's about once a year, even with really low mileage use in dry warm conditions. At this point, I can literally remove and press in new BB with my bare fingers because the frame shell is worn and super thin in that area. The BB on this bike looks impressively massive, but outward impressions do not tell the story of the Bottom Bracket bearing interface.
Has anyone found bearings for this system that seem to hold up? I could spend the $150-$180 on a Wheels Mfg unit and keep using the lifetime warranty, but I would rather not have to keep fiddling with this thing. No one seems to make a 1 piece design for this interface, and I can understand why. There are just not many bikes out there using 132mm wide BB shell with these puny bearings + 30mm spindles.
I started looking at BBInfinite who's whole claim to fame is a giant one piece BB for crappy carbon press fit interfaces, but they only offer a 2 piece design for my width and kinds of defeats the whole idea of what they are trying to accomplish and their BB's are $200-$325 depending on bearing choice.
Let me know your experience...
