1 - 20 of 51 Posts
chapman505
· Registered
Discussion starter · #1 ·
Wondering what the consensus is amoung the Trek tribe. I know the claimed benefits of increased frame stiffness and weight savings.
Does anyone else think the limitations on steering in tight switchbacks is an issue? Where I ride we have enough tight switchbacks that I'd take the added ounces to not have to deal with knock block.
Anyone else have an opinion they'd care to share?
I've noticed it on some switchbacks and corners. The bike is awesome so I can forgive it this. Thankfully I've not had to change stems so that is a consideration...
Wouldn't let it stop me but certainly wouldn't just buy a Trek for straight shot alone..
I occasionally softly bump up against it on switchbacks, but no big deal.
Annoying for transport on tailgates and in the back of my car.
For me, I just wonder why? My 2018 FEX is probably stiffer than my 2016 was, but the 2016 was stiff enough, and noticeably lighter.
Hate it. The claim is a stiffer frame at lighter weight. (Note that the top tube is now has a kink in it.) I'll take the same stiffness with the small weight penalty of the traditional bent downtube to not have the added complexity and limit on turning the bar. A number of riders I know have already bashed the knockblock to the point of not working properly, or at all. It doesn't take much. I think it's kinda ridiculous.
You can get a special washer from Trek to run a regular stem on the Knock Block bikes. Honestly though, it should just come with any bike that has this feature. ^^I'm with Lone Ranger, it's a solution looking for a problem IMO.
No issues whatsoever riding. Mine is a replacement frame so I had to but a new handlebar to use the stem to use the Knock Block....
I'm not sure if thinner spacer are available yet to fine tune the height of my handlebars.
I don't get the people saying they feel it in switchbacks... When I first heard that complaint I tried a few track stands on pavement and tried to turn tight enough to bump it while barely moving. I couldn't. The bike falls over before you hit it. That doesn't mean it's impossible to bump in a switchback, since you're at speed then, but it does mean that if you are bumping it it's more your technique than an issue with the bike. Where I ride is all tight switchbacks and I have no issues.
I have bumped it a few times in the air doing bar turns. It's kinda cool; I don't consider a good bar turn anymore unless I do and you can even push the back end out a bit by doing it... Cheater whips! :)
Whether or not it was needed is another question, but I'd venture to guess that the incredibly sophisticated R&D done at Trek knows better than some keyboard engineers... Just a guess though. ;)
This^ I really like my FEX, but this is a gimmicky feature. My vote is... Knock Block, meh.
1 - 20 of 51 Posts
