I posted this question on another forum but not getting much in terms of response to, what in my, perhaps ignorant opinion, is a rather straightforward question... so apologies if you've seen it before.
I have a 2018 Canyon Spectral AL 6 which came with a RS Pike in front and Deluxe RT in the rear. I run both fully open compression (actually there's no way to adjust on Deluxe aside from air pressure) but the shock still does not respond quickly enough, to my liking, over the small repetitive ruts/gravel/rock gardens. I also feel like I'm betting "bucked" sometimes because the Deluxe doesn't compress quickly enough. I'm about 75kg with gear and I do not want to increase SAG further because I tend to strike pedals a lot, and that would lower the BB further and exacerbate that.
My question is, are there any changes that can be made to the Deluxe RT to speed up its compression (w/o increasing SAG)? I was thinking of replacing the 7wt oil that's in there with something lighter but do not know if that will have any undesirable consequences... or if that would actually be an effective way of speeding it up.
