Harold, I totally get it, but Jack doesn't care about weight, right? So if weight is not on the table as an issue, then slime is the proper product here as the sealant of choice to use in a tube, yes?
Or you still disagree?
I still disagree.
If tubeless is off the table, then the proper solution is a quality tire. Really burly tires with good puncture protection are very heavy, too. But heavy tubes full of goop that makes a huge mess when they puncture don't work well enough to address their downsides. The tubes preloaded with slime have a large volume of pretty thick sealant in them. I have seen the stuff solidify (I don't know how long it takes, just that I've seen it), and that gets REAL fun to ride with when they're unbalanced like that. They're also a royal ***** to remove when the sealant solidifies.
Putting Stans into a tube would be a better option, but you'll still run into issues with glass embedded in the tire that puts a new hole in your tube after the first one seals (or just continually repuncturing the same hole).
This is for road/commute/city bikes. For mtb's ridden off road, Step 1 is to go tubeless for me. The ability to shove a plug in a tubeless tire, reinflate, and continue riding is soooooo much nicer than trying to fumble with tubes. And something embedded in the tire? Who cares? The sealant took care of it. I might occasionally run through a tire and dig that stuff out, but chances are good that there's a layer of dried sealant covering over it so you don't have to worry about it puncturing your tube immediately if you need to put one in.
Step 1: Pay attention and don't ride over junk. Make sure your pressures are sufficient to avoid pinch flats.
Step 2: Buy good tires with puncture protection (only if the first option is not working well enough or you wear out your tires).
Step 3: If you are STILL having persistent flat problems (a very occasional puncture is nothing to be concerned with - even with sealant, you'll encounter the occasional puncture or cut that won't seal), then revisit Step 1.
Step 4: THEN consider a tubeless conversion (don't do a new tubeless conversion on old tires, though - use fresh ones). For people who deal with goatheads on the road, they'll get to this point pretty quickly. For others, they may not ever get there.
Step 5: If you want the most durable option available, period, consider airless or solid rubber tires. Most will ride terrible, but they won't flat, that's for sure.
Step 6: If you're cheap as hell, and won't buy quality tires, then buy shitty slime tubes and deal with the fact that they're a little better than no sealant, but have a lot of downsides that outweigh their small upside.
