This looks interesting. Screen grabs from an EMBN video about Fazua Ride60 show what appears to be a lightweight 60NM Pivot Shuttle SL.
It's 35nm. Like you, I ride a mountain bike as well as the E-bike. I'm sure that to someone coming off a FF E-bike that has around 80-90nm, the SL would feel anemic. On the other hand, I feel like I have Tomac legs when riding the SL (compared to when riding my mountain bike).I'm not sure what the Levo is...30? 40? Anyway, I use ECO 80% of the time and Trail 20%. I find Turbo too much for single track.
You're right, but also with some choice changes, you could keep the weight about that of the WC spec.Honestly seems like a really nice bike, but the click bait weight on the thing is a bit of a farse. The advertised ~37lb weight is for the team version... add a float X and fox 36 over the dps and the fox 34 and you're adding around (700g). That advertised weight is also with a KS Lev CI... which is a rather shite seat post for the application with not quite enough drop, so adding a real dropper post would add another 300g. Tires are rekon's, so putting real tires on it, is another 400g minimum, most likely 700. That weight also includes some rather feather weight reynolds wheels, so add another 300g for rock strike proof wheels or at least cushcore. One also has to assume the stated weight is for a size medium frame... so add another 500g for a size L... 600ish for an XL.
Likely all adds up to the Pro X01 build in size large being around 42ish lbs. Not bad, but not really any different then an orbea rise or levo sl.
I'm stoked to see more of the lighter weight ebikes come out... I much prefer them to a full power, full weight bike, but I think staying grounded on what the actual riding weight will be is important.
