81 - 100 of 705 Posts
I went for enduro and have no need for Downhill. Looks cool but I don't see any benefit for my riding. I know that the refrigerators will be available separately in short time.
The Intend massive rotors didn't work well with my Maxima (neither did the Trickstuff UL/HD, TRP). Only with the Galfer Wave Disc V2 there was silence. I will try the green pads once the Intend pads have worn but they seem to last a very long time. I practiced stoppies a lot and couldn't see any noticeable pad wear. You can hear the rubbing sound I have with the Intend pads and Galfer rotors. It's not that noisy as with the Maxima but it's there.
Have you tried the Galfer disc rotor V1 also?
I actually can't believe I paid 70 euros of shipping for sea shipping. It's a scam (not blaming Intend, but they should avoid DHL).
Are you sure it is coming by sea? When my Maximas shipped, they sat at DHL for about a week until they got put on an airplane, the DHL tracking info gave me the flight number and everything. Have they indicated it's on a boat or has tracking just stalled?
I also can not believe this. Shipping was 40 euro and my dhl tracking has now updated and states that it is transported by sea. Seems crazy for a parcel under a kilo and it being a premium product and price. Whenever I've ordered stuff of r2bike(sets of tires, liters of sealant and some bits).... also German. It has been here within 2 weeks or less. Without huge shipping cost and occasionallyit even bypasses customs. Oh well, nothing to be done about it I suppose. But it sucks big time
Yes it could be better to have the choice about shipping, but I assume Intend can't provide choice as they are only six to run the shop :)
I'm curious how they handle shipping small parts and warranty stuff then, it's a little concerning to think that it could be 30+ days getting replacements if something happens. I know they are nice and responsive folks from what I've heard, but if they are blanket opposed to faster shipping then that might be an issue.
I may be ordering some spares when mine show up tomorrow, I'll report in on that when I get a chance. This is why I always keep a spare aside for any boutique things especially those made in Europe.
When I ordered extra pads and the refrigerators for my set it only took a week or two to get them if I remember right
Ironic timing. I managed to order a set from @SMP11 (THANKS!) but I also unexpectedly due to a series of circumstances landed some direct from Intend. I was sick with COVID, not sleeping, and happened to be on the site when they dropped so I snagged a pair for my wife's bike after I had agreed to buy his. Her brakes suck, now they don't. The irony is I was complaining about timing because mine hadn't shipped yet, but they showed up at my door about an hour after my earlier post, 9 days after ordering to the US (NC), so not bad.
A few thoughts.
Install was easy. I like the way you can disconnect the hose barb, although I wish they'd publish a measurement or something you can use to know it's fully seated. Pushing the barb in was super easy even with a janky tool. The front came close to the perfect length for my 150mm RXF36 m.2, so I just left it alone. The rear was empty, so I trimmed it to length and bled it, which was easy-ish. I like how the bleed block just drops in and stays in place, that is really clever, but I did have some issues getting air out of the caliper. It wasn't as straightforward as shoving fluid back and forth, it took ~5min of sucking and blowing to get it all out. I've had way worse, so I can't complain, it was pretty painless if you compare it to some brands, but it being empty makes it require more effort than some that come fully bled. I really like that they have a second screw to close the bleed valve, this is something only SRAM does similarly and I wish others would do, I know it's probably hard to manufacture but it would make bleeding a lot cleaner/easier. I'm not a huge fan of slide on levers, but it is what it is, again I'd like to see a hinged lever mount here but it's a minor gripe. I do wish they used standard screw sizes instead of small Torx also, it's gonna be tough to adjust on the trail if you need to, although my larger multitool has it on there.
The lever feel is really light, the deadstroke is short, and the pad retraction is good. The lever feel isn't as light as the Maximas is especially when the pads engage, but they seem to ramp up faster for the lever distance you pull. The deadstroke on the Intends is much much shorter, not Radic short, but close. Where the Maximas require a bit longer lever stroke, these come on a lot quicker and more powerfully, it feels like the power available is more usable, but at the expense of lever force once they engage. It's marginal and really light feeling, I'd say better than most brands, but not as light when the pads engage as the Hope T4 V4 or Maximas are. I think how this works for people will be a matter of preference. The pad retraction is better than the Maximas and getting them drag free was trivial, easier than MT7s or Maximas, on par with Dominions/Shimano/SRAM. I found them fairly easy to modulate but they aren't a super long, linear lever pull to get power out (like Codes).
The available power is really good. I think the Maximas might produce more power, but you have to run the levers further out to obtain it due to the more linear pull and amount of deadstroke, it comes on faster with these, more like the Mavens or possibly Dominions, just with a lighter lever feel than both. I feel the power is more usable, in other words, unless you like long lever strokes. The lever ergonomics are a little different, I think it's easier to grip than the Maximas (which has a smoother lever), but the hook tip can be painful if you have them positioned inboard.
There is one point of caution though. The usable lever blade is short. What I mean by that is the position between the brace on the lever reservoir and the tip of the lever is short. If you use really large grips or like your levers positioned really close to the outside of the bar, then these may not work for you. I had heard this from someone else and while they are fine for me, I can see how they'd be a problem for others especially if you use really wide grips. The flip side of this is that, more than the Maximas or Mavens, you have more flexibility with dropper/shifter position. I had to move the body of the lever close enough to the grips that if I bumped the shifter/dropper lever against the lever, it would be way too far outboard, so this is an improvement over those options that required me to run the other controls further in than I'd like, but again, if you need your levers really close to the grip you may have problems.
I didn't get the noise mentioned previously with the white pads and new Trickstuff rotors. They were largely silent, quieter than the Maximas, but I also didn't ride in the wet yet, just one very dry smokey ride thanks to burns and a moderate ride today on some chunky stuff but nothing super steep.
Today's drop sold out in 6 minutes but managed to snag a pair. I plan on running it with Trickstuff 850 power pads and SRAM HS2 rotors. Right now that bike has Code Ultimates with that pad+rotor combo so let's see how the Trinity likes it.
I carted instantly and thought I got it. Faffed around adding matchmakers and looking at brake pads, then when I pressed checkout it said no more stock.
Maybe it's just me, but maybe someone out there will learn from my mistake, checkout instantly. Getting it in cart isn't a done deal.
That said, it didn't feel so impossible to get. If they keep these production numbers up it'll be alright soon. I hope.
Yea, with high demand, low stock goods you are always better to buy immediately. Another trick is that you can avoid one site load but keeping another window with the checkout page open (I did this by adding something to my cart, going to checkout, then removing it, I kept the page open, tabbed over to it, and refreshed after I added the brakes).
Paying by bank transfer probably cuts out the delay with Paypal too, even Intend suggested doing that. I went through Paypal for the set I got from them and by the time I got back there was only 1 set remaining, all 14 were available when I started the process.
Congrats. I haven't played with pads yet, but the stock pads seem pretty grabby. Might be worth a try before jumping straight to something else unless you plan on using the same rotors you already have (which would make sense). I'll probably try the Trickstuff pads when the whites that come with them wear out for comparison sake, but they aren't like most brakes that come with crap brake pads.
No doubt the intend pads are great but I only recently installed and bedded in a brand new set of TS pads + HS2 rotors on my short travel trail bike. This way I can easily swap the brakes and ready to go. A have a new set of TS Maxima on the Enduro bike for comparison so that will be fun.
Another tip on successfully checking out is by adding all the accessories in your cart the night before. Also ensuring that you are logged into PayPal and have your payment card of choice as default etc and lastly use a properly synced world clock. This was actually easy compared to the Nvidia cards during the pandemic :ROFLMAO: At least we don't have to compete with bots.
ya I forgot to mention I logged into Paypal in advance.
Re: Maxima. The Intends have a bit of a firmer bite point when they engage, it's not exhausting by any means but it's not as light as the Maximas. I found the Maximas to have a much more linear power delivery, where the Intends ramps up faster. I'll be curious if you find the same or not.
Seriusly I missed a drop???? Notice went to my junk mail folder. Sounds like they went so fast it was hard to get anyway but damn I would have tried.
Has anyone had issues with these dragging against the rotors? My rotors are true and I’ve tried several mounts. They start out fine then after a bit of riding they start to squeal when not engaged. It’s like the pad is just barely touching the rotor but I can’t seem to get it to stop
