Title goes here
I don't have any feedback for the chainsuck, but I can comment on the suspension.
First, your SB has a completely different leverage curve than the Mojo. The SB has an extremely high initial leverage which offers maximum small bump sensitivity at the expense of some efficiency. The rate than aggressively drops toward the end of the stroke for mechanical bottoming control. Very Moto-like. This gives a very active ride characteristic. The Mojo has a fairly flat initial rate with a slight drop at the end for mechanical bottoming control. This offers a suspension characteristic that's more neutral. It too can be made plush, but not too the level that you had on your SB. The Mojo, however is extremely efficient and balanced.
Second, would be the Propedal compression setting from the factory. I've attached a picture of how you can tell where yours is set. The picture attached shows position two. One is the softest, three is the firmest. Your shock is designated by which bar is highlighted white. Depending on your rider weight or style, the level of compression that your shock has might be too firm for your application. By softening the compression settings you'll achieve a more plush ride with more through travel, but will also slightly compromise how much firmness you get in the Propedal "on" position. It's a bit of a trade-off, but not as big of a concern with a dw-link bike due to the mechanical efficiency.
Third, is High Volume air cans. At 185lbs completely geared, I'm currently running both a High Volume air can on my RP23 as well as our new High Volume Air Piston kit in my Float 140RLC. I'm an experienced rider who rides light and doesn't mash into things generally (only when testing suspension components) but I do ride the "big lines". The fork psiton kit is a must for me, but I'm still trying to work out whether or not I'll stay with the big can in the back. What I will say, is that High Volume air cans are USER specific and NOT frame specific generally. It doesn't matter what the frame characteristic is, if a rider can't get full travel, they can't get full travel. This is where the HV can comes into play. Some frames are less friendly than others to HV cans, but at the end of the day it comes down to the user and his/her application. Now, if you're bending shock mount bolts......we need to talk. :thumbsup:
Darren
