Ibis Ripmo V2 Thread
1 reading
491K views 1.9K replies 329 participants last post by  jshuman
#1 ·
Available in Star Destroyer Grey and Bug Zapper Blue, the new Ripmo V2 has a one degree slacker head angle, improved lower link protection, updated dropper post cable routing, more progressive and coil compatible, and it's a smidge stiffer.
#1,174 ·
Joined team Ripmo today. SLX build with a 38, X2, We Are One Union/I9 hydras, and We Are One Da Package bar/stem first impressions are really good, but we’re still getting to know each other. View attachment 1964878
Welcome! And man….Those front steps and slope leading from your front door (assuming that’s your house) looks fun as hell to send on a daily basis. [emoji23]
#1,177 ·
If it’s a brand new bike with fox suspension use Ibis settings. If you buy aftermarket fox stuff then use fox settings. It’s not as much about kinematics as it is about the tune on the damper. Ibis is one of the few brands that changes the tune in their stock fox forks as well as rear shock (on the X2), so keep that in mind if it’s a traction tuned fox fork/X2 that came with your new Ripmo.
You can check the tune codes to verify
#1,181 ·
This thread needs more pics from the trail :cool:
I found an XT build in XL (I'm 6'2") buried in a shop in a different state. They're going to box it up and have it sent to me. All the local shops are projecting to have more bikes in ... June. Not great.
Can't wait to get on this thing. I'll update with pics as soon as it sees dirt!
#1,211 ·
Any V2 owners who are 5'6"? What size are you riding?
I demoed a medium, and it felt just a slight too big. Problem is the bike already comes with a 40mm stem so there isn't much room for adjustments.
Also demoed a small and I prefer the handling of the small, but the top tube is too short. I can touch my knees when I turn my handlebars all the way.
#1,213 · (Edited)
Im 5'6" on a good day anymore - medium all the way. You will find it works extremely well, more nimble than numbers like Wheelbase would suggest. IN fact - Id go real far to say, I'd never ridden 'this big" a bike from a geo perspective(last bike was 1.5inches shorter WB) and once I was a couple rides in , there wasn't and isn't a trail or locale I wouldn't ride it. My last bike and little bit older geo standards was smaller, shorter, etc... Ripmo don't care - it will go and do where rider points it and tells it to. Very intuitive, easy to ride etc...
#1,215 ·
I'm 6'4 and I've had my XL V2 since last year. Overall I like it, though jumping to modern geometry from a ~7 year old bike took a little getting used to, and I still feel like the bottom bracket is too far back in relation to the seat. The biggest issue I have is that I feel like I'm tipped too forward and have too much weight on my hands. Climbing is great, bombing down a hill is great, traversing...kind of sucks, and I do a lot of that. This seems to be a common complaint with the bike and advice I have seen is to tip the nose up a bit more and add rise to the bars, either via the stem or swapping to riser bars. My saddle height is EASILY 2" higher than the top of my bars.
I'm curious if others here have solved this via a new stem or bars, and if so, what riser bars you recommend.
#1,219 ·
I'm shorter than you, at 6'2" on an XL V2, but I added headset spacers to take my weight off the front. I think it was +10mm from my original bar height (even with my old bike). I later removed one of these spacers when I switched to a 170mm air spring. It seems trivial, but it made a difference in how much weight I was carrying forward in the steeps through bombholes.
If you feel like this will cramp your reach, you could go with riser bars instead.
