Available in Star Destroyer Grey and Bug Zapper Blue, the new Ripmo V2 has a one degree slacker head angle, improved lower link protection, updated dropper post cable routing, more progressive and coil compatible, and it's a smidge stiffer.
If anyone is looking for 165s, I have a set of M8100s (XTs).Talk to me about pedal strikes. I'm in SoCal and riding the usual local chunk and rock gardens.
I have a Lage V2 XT build on order and I requested my dealer swap to 170mm cranks (175mm is standard on L/XL frames). I see quite a few people mentioning they're running 165mm cranks on their V2's. Should I go that route?
Pretty sure they are 25x8 and 15x8. That's going off memory from a little while ago.Can anyone guide me to what mounting hardware I'd need for a float x2 install? I see a few options on ibis here: Parts - Ibis Cycles Online Store
Ya, I was running a Kitsuma Air on my Rip. Let me just say that I'm a big CC fan cuz I'm big and they've been reliable. I have a DBA on my HD5 that's great. I have a Kitsuma Air on my shorter travel 29er that I also like. But, I could not get the Kitsuma and RIP to get along as much I'd like. I even emailed CC for advice, which I found wasn't very helpful. So I sent in my Topaz to DVO for a custom tune not too long ago. (DVO custom tune is cheap FYI)Has anyone run a Kitsuma shock on one of these? Cane creek says the Compression range would be just fine but have heard at least one person say the shock is way over damped for the ripmo.
Also, if anyone has a siz L frame for sale, shoot me a PM!
Having worked with Ibis warranty fairly extensively in a shop setting, I would rank them above Trek but below Santa Cruz. Trek makes you jump through lots of procedural hoops before anything gets done and usually require you to send in the part/frame in question to start the warranty process. Even parts/frames approved for warranty usually take weeks or months to replace. More often than not, they offer the customer a fairly weak discount on a new bike, say 20% off. Santa Cruz barely asks for anything before they send out a replacement part/frame and a call tag for the old one. Usually the whole procedure is one week or less. Ibis is in the middle, they specify a lot of things as "impact related" but will usually work with you some to find a compromise and are pretty responsive.Ibis quality, warranty and the nitty gritty
Need to went a bit - letting my thoughts about the Ripmo out
Has anyone else had problems with their Ripmo v2 frame? I cracked my size Large in one week and now Ibis won't put it on their warranty. Cracked while riding, nothing extraordinary, you know just riding along and all that. I suspect a stray rock hit the downtube near the bottom bracket. There are scuffs on the downtube protector and the paint has started to chip below the protector. The spot sounds hollow when knocking it, compared to the frame elsewhere.
Ibis claims that that because this is an impact it is not covered by warranty. This might be true but I think the frame should be able to handle a few stray rocks. So if this is normal, and thus not a warranty case, then the quality or design is bad in my opinnion. What does the community here think?
There is a crash replacement sceme, but I have yet to hear what the cost for a new front end will be.
Other issues
I've also lost the metallic plate chain slap beneath the chain stay, came loose in the same time period. Doesn't improve my thought on Ibis quality... I've now added a bit of an old inner tube wrapped around that spot on the chainstay to protect the rear triangle and to quiet the bike down from the chain slap.
Talking about noise, how have you remedied the cable rattle on this frame? It's wild how much noise those make! I used some electric tape and zip ties to secure the cables at their ports.
Specs
I have the 2021 spec with SLX build kit, inculdes Fox Factory 36 and X2. Ibis recommended settings are a good start generally, but the fork in my case needs more high and low speed compression damping or/and less sag (more pressure) than recommended.
Looks like the 2022 model will have the burlier Fox 38, Ibis EWS team uses that one. Interesting to see what lenght the fork will be. Personally I wouldn't mind a 170mm fork and a slightly slacker head angle, then you would be able to ride with less sag in the rear for the same sag% in the front and avoid some of those pedal strikes and have it set up for some steeper trails.
My ride on our Instagram page
Pedal strikes and those cranks though. Why spec 175mm cranks? I keep hitting them constantly. Need to order 165 or 170 ones. Other wise the spec is solid. Sometimes I'd like to have more power from the brakes though. Otherwise the groupset works well. I had to adjust the chain lenght (cut one link out in my case) to get smooth shifts all the way through. Shimano's instructions for measuring the chain are good but not fool proof I guess, haha.
Loving the Bike Yoke Revive dropper, it is an absolute treat!
Linkage bushings and bearings
Has anyone done a full linkage service yet? I was excited about the bushings and waited for care free miles, but somehow I missed the fact that the upper link has 4 small ballbearings in it. I was so looking forward not needing to take care of linkage bearings but one of those had already started to bind. I've only done 370miles (600km) on mine. Cleaned and re greased the busings already (not needed at this point really) and tried to resurrect that one bearing by wiping the old grease out and sticking fresh grease in beneth the dust seals. I'll have to keep an eye on those, sigh.
by ESF , on Flickr
Sorry for this messy post- just needed to get theese thoughts out of my head - I'm sure many of these topics have been discussed here earlier, I need to start reading through this thread.
All and any replies are welcome!
by ESF , on Flickr
