Available in Star Destroyer Grey and Bug Zapper Blue, the new Ripmo V2 has a one degree slacker head angle, improved lower link protection, updated dropper post cable routing, more progressive and coil compatible, and it's a smidge stiffer.
In one of their older set-up guides, they said to use 14mm for trail riding and 16 or 17mm for park or DH/shuttle riding.Can someone please explain Ibis's math on their sag recommendations. It seems they are calculating sag based on 50mm stroke and not 55mm路
"30% sag = 15mm stroke"
XT may be backordered but get it if you can. finest drivetrain you can get IMO. thomson stems are way over-rated. sell it and get a syntace megaforce 2. or flat force if you want to get low and dont mind toptube/lever interference. get the fox if you can get grip 2. DVO shock is based on the old rockshox monarch, nothing too special really. sorry. flamesuit on. im partial to the new rockshox stuff. fox will probably be easier to sell so i'd just go full fox and if you dont like it go RS aftermarket. especially if you can snag the new X2 with the VVC on compression ciricuit. youll probably like the new grip2 fork if the CSU doesn't start creaking first tho.Since I can tweak the build, what are the thought on GX vs XT?
Yes, a shop in Santa Cruz had 2 larges a few weeks ago. I bought one.Anyone having any luck with finding a Ripmo in a timely fashion? Hard to believe they are 1/2 year out...for a bike?!?!
Sent from my iPhone using Tapatalk Pro
I had an XL Ripley LS with 70mm stem 800mm bars and now ride an XL Ripmo with 45mm stem and same bars.Ok, so it seems demos aren't out and I'm not sure what size I'd be in case I can find one online? I'm 6'1" and have an XL 2017 Ripley LS. No way a large Ripley would of fit me that model and year anyways)
That said, I haven't ridden the new geo bikes with longer reach etc. the old ibis's seemed to run small...you think I'd still need xl ripmo or would a large ripmo work?
