I have a narrow wide chainring (Race Face, 40 tooth) on my cross bike and I think it might be nearing replacement time. It is skipping under load but only really high load (like standing on a climb steep enough to be in the easiest 2-3 gears).
In case it is related I wanted to include that I just put a power meter on this bike and I had to adjust the derailleur afterwards. The crank uses a proprietary crank spindle which needed a different combination of spacers than the stock one to fit right so I think the chainline may be a hair different. 2 clicks clockwise on the barrel adjuster got the derailleur perfect so any difference was a small one. Just wanted to include this in case it was relevant.
The chain is not stretched whatsoever and the cassette is in great shape according to my Rohloff cassette wear indicator (both have <500 miles, chainring is around 2k miles). See pic. The black finish on the teeth only lasts a few rides so that isn't really an indication of wear. I've worn 30T Race Face rings in <500 miles so if this one is cooked at 2,000 miles I'm fine with that. None of the squeaking noises I've heard with worn rings in the past though.
