To make sure you understand "why" this happens...
Typically, when you go to a longer travel fork, you gain the extra travel by the forking having to be taller at the upper sanctions(but the lowers are also deeper to acct for the extra overlap at full stroke, or you half to have less overlap to start with at the upper/lower junction). So, when its bottomed out, its normally at the same height as it was with the 80mm(when it was bottomed), but it rebounds farther away from the wheel, where it had to gain the extra length...soooo, its sorta like a very short chopper now, in laymans terns. Tihs is an over simplification, but effective nontheless. The longer a fork is compared to the oem setup, the slacker the angle/handling. Will show up in the tight stuff first. Meaning less willing to turn in tight stuff. More "floppy" maybe in extreme instances. You get the idea.
Duck
