Homebrewed Components Alternative
51K views 299 replies 72 participants last post by  tehan
#1 · (Edited)
Bring 'em on!!:thumbsup:
The MRP spiderless looks nice to me. A buddy just got one and loves it..
No..I don't work for MRP..
Multiple colorways soon too..
#14 ·
Well, I know folks have used Boone and Blackspire in the past with good success though I have never really seen places to order either of them. You can also look into Rotor Q as they also have an SS ring though it is an elliptical shape.
If you have a M960 crank you are very limited however due to the odd 102 bcd but I believe Blackspire makes one that fits. (unfortunately, this is what I have so the HBC is the best option at the moment as far as an SS ring goes-not because of customer service)
#22 ·
I know it would be for me (SSr) as you end up with tight/loose spots. They say it is minute but you can still see it when you rotate the pedals, at least that has been my experience anyway. I actually have a little bit of that going on right now with my HBC ring and Surly combo. I thought maybe it was the new Surly cog that I have so I slapped my White Industries set up back on and still have the issue.
One thing you can do is mark how you mount it when you first put it on. If you have a tight spot, you can try to take it off and rotate it to see if that helps even things out. I have heard that it can also be the actual bolt locations on the crank as well. None the less, I have been doing fine with it but I certainly would not want to buy one knowing that this is an issue.
#24 ·
I heard about the MRP problems from a friend yesterday. He's running an MRP and just ordered a new RCR ring today.
By the way, if your ring has bolts, you can try to set the cranks at the tight spot, then loosen all of the chainring bolts, allowing the chainring to scoot over ever-so-slightly, then tighten the bolts again. Most rings have low enough tolerances at the bolt mounts that you can get .5 mm or more by doing this.
#26 ·
Hi guys,
Pro Bike Supply does not have the rings in-stock, be warned. There has been at this point (6/6/2012) only one production run, and that production had the imperfection mentioned (ie probably not suitable for single-speed use).
We are currently producing more and adding 34t and 36t as well. I don't have an ETA. They are being machined right now.
We have no plans to make the Bling Ring in any other colors.
Cheers :thumbsup:
