Hi all,
Been a while since I've been on here, but have always received great help so that's why I'm back!
I recently picked up a 2013 Trek Stache 8 that I have been loving for the past few weeks, but ever since I got it the rear break has been a little squishy. The lever could close all the way to the bar, but was grabbing enough that I rode it some. I did not notice any leaks of fluid at this time.
I've only have BB7's until now so I figured I'd have a go at bleeding. I am using Shimano's bleed cup and fluid, and ordered a generic syringe off amazon that fits into my 1/4" hardware store clear rubber hose that seems to fit the bleed port well enough.
On my first try at it I was able to push fluid up the line into the bleed cup. the fluid was cloudy and very dirty so I kept going until it was clear again. Pushing the fluid up seemed a little bit harder than I was expecting, but I could tell it was moving slowly. After this I went up to the lever and it had good feel but continued on with shimano's instructions to bleed from the bottom port. I strapped the lever to the bar and went down and cracked the caliper valve a few times and saw some more dirty fluid coming out. Closed the port and went back up to the lever and now it is soft with no feel at all.
It seems like I was close to a good bleed but did something that got air into the system. Am I doing this wrong? should the lever be returned while the bleed valve is open?
Additionally, following a two more unsuccessful bleeds I cleaned everything up and tried to pump the lever a few times. At this point everything is back assembled and I hear some bubbling coming from where the reservoir cap meets the reservoir. I can see some seeping out from the front of the lever body. I only removed the bleed port cap on the top of the lever so how is it that now I have a leak?
