Help with fork upgrade on my Riot
4K views 27 replies 10 participants last post by  Fancy
#1 ·
I’m looking to finally upgrade the fork and shock on my Riot. I think for the shock I have settled on the Chubbie/Woodie. I was going to spring for the 11.6 but in the end I’m just worried about spending so much money as I’m also looking at a fork.
As for the fork, I’m either going to send my 34 factory into Craig at Avy and have him work his magic, or I’m going to get the Ribbon Air or Helm Air. Something I just saw on the Helm air is that the A2C is 558mm on the 150mm. Seeing as how the Riot was built for 551mm, that might be worth a shot.
Does anyone out there think one might be better vs the other? All geared up i’m about 155lbs and ride a bunch in VA/WV with some parks speckled in (though mostly flow vs nasty chunk). My main issue with the 34 is how it is a little undergunned in consistent root/rock hits. The easy fix is to send it to Avy, but I’m just not sure if that’s worth spending the $600ish on or just going a little above that to get a Helm.
Thanks for any and all advice.
#3 ·
DVO Diamond fork totally surprised me by how good it is. I am 185 body weight, so all of these factory forks are kind of built around my weight. I was on FOX forever, then switched to PIKE on 3 bikes over the last 4 yrs. I also like the Lyrik on a 170/170 rental bike. But the Diamond is as good or better. I give up a 1/2 pound as its heavy. They can be had for $600-$700 if you are rolling non boost. Arts cyclery has a few Push 11.6 shocks on clearance for other frames but maybe they carry over to our Riots? As Ralaighguy said above, the DVO Topaz is great. It's as good as my old FOX rear air shock.
#6 ·
At this point I'm going to go 150 for sure. I wish the bottom bracket was a little lower, but I'm sure it'll be fine. I have a couple spacers under the stem that I'll remove when going 150. I've settled on the Chubbie/Woodie as I really think I need a coil in the back. Still regret not getting a Large, so this is the best I can do.
#10 ·
I think Avy mod is probably better than Diamond, not sure. What I will say, is if you are average weight aggresive rider, a Diamond at $600 is awesome vs a new $1000 fork (plus tax). I have heard great things about MRP, by Sam, owner of Over The Edge Bikes, in South Lake Tahoe. He has a small rental bike fleet with MRP forks and likes them alot. He also has used a DVO Diamond I Believe he said. Alot of great forks out there.
#12 ·
I have Avy front and rear. I dont have any skipping in the rear. The Avy shock blow enough HSC to keep things calm. DVO is a good company and you can tune and rebuild things on your own. But the Avy shock you just need to seen it to Craig every 3years and the fork cartridge just change the oil when you do a lower leg service (need to drain anyway) this year i got the push coil kit for my Yari since i needed to keep servicing the air spring to keep stiction at bay. Now its the best fork ivr ever ridden.
#13 ·
Good to know on the Avy. I think I'm 100% going to get the Chubie rear. Although I just demoed the SB130 on Friday and came away pretty impressed. Now I've got some problems haha. Either drop some coin into upgrades or go the 130/150 route and bring over some parts. Still have to say, even though I enjoyed the climbing and pedal efficiency of the 130, the Riot is still impressive.
#17 ·
I went back and forth on the Riot pluses and minuses with both. 44 felt like i lost some HTA and the wheel wants to tuck in sharp turns. 51 is quick and can wash out. 44 would be more comfortable on longer straight downhills. But the Riot isn't a long bike. Longer bikes or longer forked, i would like the 44 so on the balance i would run shorter.
#18 ·
Thanks that makes sense. I had a bike and went to a 170mm 2018 fox 36 which I believe is 44mm. I'm about to replace it with a 160mm MRP Ribbon which comes in 39 and 44. I haven't seen many 39mm and think its part of the Transition offset geometry push. I already run 38 risers on my balance so i can get my bars at the right height without sacrificing my reach (bringing the bars closer to me with spacers) so I don't want to give up any reach.
#20 ·
Ill post this in a few places. Some bikes are more harsh with the derailleur clutch engaged than others. The Riot has a lot Antisquat through the whole range of travel. And i feel a big difference on fast hits with it off. So try turning the clutch off to see how it feels before you go big money on a rear shock or give up on the bike. A chain device may just be what *
#21 ·
+1 for the Avy on the rear. I'm running a Woodie tuned by Craig with a 400 lb spring at 158 lbs geared. Love it. I can't speak for a Ribbon or Helm on the front, but I've got a Fox 36 at 160mm that works so good coupled with the Woodie in back. I built it with a zero stack bottom headset so the geometry of the bike is really not much changed at all.
#26 ·
I vote 11-6 for the rear if you can swing it. For me it changed the bike so much for the better that it's totally worth it. As for the fork I again vote for the push route if you can swing it. I'm using a 150mm fox 36 with the ACS-3 coil conversion. Bike is a straight beast. So much fun.
Would love that option, but that is some serious coin. The 11.6 is a good chunk, but buying a 36 and then the ACS-3 Coil will result in my wife killing me. Getting the 11.6 and leaving my 34 on the front would probably be a disaster (just a guess). Although sending my 34 to Avy for the works is going to cost around $600 or so. Which is what got me in this predicament.
Just thinking if I'm spending 600 on that it might be worth getting a beefier fork like the Helm or Ribbon. Some still say an Avy'd 34 is better than the Helm or Ribbon, but I'm just lost.
