Hi, I took the derailleur jockey wheels off of my GX Eagle and was careful mark which side was facing outward to start with. However, I was not as diligent enough, and now things don't sound quite right. I noticed that the there are two different types of washers, three with a raised bevel and one a lower one. I have found exploded view on SRAM's parts catalog, it is still very vague. So, what's the correct way to do this ?
Raised on left, flatter right
For Upper wheel - use shorter screw, flatter washer inboard, raised outboard , looking carefully I see a 'U' on the wheel and that is facing outward
For Lower wheel - use longer screw, raised washers both sides , looking carefully I see a 'L' on the wheel and that is facing outward
