For 2021, I’m considering taking on a project of getting my trail bike lighter. Is it practical? No! Is it moneywise? No! Why do it? Because I love wrenching on bikes. Because I want to! Because it will be a fun project. ‘Murica, and all that jazz.
Last night I took apart my bike. Every nut and bolt. Gathered each sub system, and weighed it individually. I figured this was the best way to find out what components on the bike weigh too much, and where to get the best bang for the buck for parts. It also lets me predict the weight benefit from a part swap.
The goal is not absolute minimum weight, I can’t buy $400 components for every single bike part to maximize the weight loss. The goal is to identify parts I can get a meaningful weight loss with a meaningful investment. Like an $80 handle bar. Or a $100 cassette. Stuff like that. Hopefully drop a few pounds.
I hope you guys can review my parts list and see if there are any parts that raise red flags to you guys as obviously heavy. And then I can focus on those to find reasonably priced replacements that give a reasonable weight savings.
Here’s the list!
Frame 2.877 kg
Fork 2.153 kg
Shock 698 g
Stem 216 g
Handlebars 413 g
Bottom bracket 238 g
Cranks 615 g
Cassette 631 g
Pedals 369 g
F brake rotor 142 g
R brake rotor 101 g
Chain 261 g
Seat 302 g
Seatpost 556 g
Rear derailer 288 g
Rear shifter 161 g
Rear brake 337 g
Front brake 310 g
Bottle cage 125 g
Saddlebag 119 g
Tool 61 g
Front wheel 868 g
Rear wheel 1.225 kg
Rear tube 337 g
Front tube 298 g
Tire one 1.385 kg
Tire two 1.415 kg
Total weight 16.258 kg
Three notes:
-Tires are obvious!
-Tubes are a HUGE surprise. My rims are not tubeless, but I will redouble efforts to go tubeless, that is almost 1.5 lb!
-Fork. Part of this project is inspired by wanting to find a takeoff Fox 34 150mm. I want a new fork, if you have suggestions for something I can find on pinkbike as a takeoff for 300-350.
what else do you guys see?
Here’s the list!
Frame 2.877 kg
Fork 2.153 kg
Shock 698 g
Stem 216 g
Handlebars 413 g
Cranks 615 g
Cassette 631 g
Pedals 369 g
F brake rotor 142 g
R brake rotor 101 g
Chain 261 g
Seat 302 g
Seatpost 556 g
Rear derailer 288 g
Rear shifter 161 g
Rear brake 337 g
Front brake 310 g
Bottle cage 125 g
Saddlebag 119 g
Tool 61 g
Front wheel 868 g
Rear wheel 1.225 kg
Rear tube 337 g
Front tube 298 g
Tire one 1.385 kg
Tire two 1.415 kg
Three notes:
-Tires are obvious!
