1 - 5 of 151 Posts
albxor
· Registered
Discussion starter · #1 ·
Hi, I did not find this info using the search tool,
I will order a Mojo HD3 but not sure about the size Between M and Large.
I am 5' 10" (177 cm) normal proportions and I want to use a stem of 50mm.
unfortunately I cannot demo any size.
Discussion starter · #22 ·
Hi, At the end I ordered the large. and Its Ok for me. maybe the medium also would be ok.
Being between sizes is not that bad you can choose one or another and use a larger or shorter stem.
Discussion starter · #24 ·
albxor - Thanks for the reply! I do think both a large and medium would be rideable for someone 5"8"ish. But that's allot of cash to drop and discover the other size would be a better fit.... I have always used and enjoy the feel of a short 50mm stem. Don't like the twitchy feeling of longer stems.. What size stem did you put on your large?? Anyone else at this height/size range riding a medium?? Thank you!!
Currently have a 60mm stem.
1 - 5 of 151 Posts
