rustus said:
One post above mentioned avid full metal jacket cables, I wonder how they compare to aztecs' power lines for performance and ease of installation and maintanence?
Never used the Aztec Power lines, but have had the FMJs on my bike for over a year, before upgrading to hydro. They really made a huge difference in the strength of the brake. The are also lighter than standard ferrules, so you save a copule of grams, although that isn't probably a concern, since you're gonna be using what's probably the heaviest disc brake on the market (other mechanical brakes might compete).
The installation is pretty straight forward, however, you will need a small pipe cutter to trim the stainless steel pieces to desired length. In addition, depending on your front fork, guiding the steel piece might cause you to think a little. Otherwise, well worty upgrade.
The only problem I ever encountered was a really rough wreck in a rock gardens section of one of the trails I ride. I am not sure how it happened but the stainless steel conduit around the front fork got bent ~60 or 70 degrees. The cables still moved inside, so I made it back home, but it was a major pain to disassemble the brake and remove the stainless steel piece and trim it a little. I also had to replace the section of the ferrule with a longer one. Possibly if I had a better cable routing method I could have avoided the problem.
_MK
