I was planning on running a Shimano XT 24-34T crankset and a Shimano side swing front derailleur ($5.60?!) along with a Shimano 11-40 cassette, which will get me the 24T-40 low gear that I desire. The latest word from Ibis is that the front derailleur won't "work". It's a direct mount front derailleur and the cable comes in from the right side ("side swing"), so it's the correct front derailleur. Essentially Ibis seems to be saying that Shimano doesn't know how to make a front derailleur that shifts properly, which baffles me because my current 3x10 Shimano drivetrain(with a bashguard in place of the big ring) has a front derailleur that shifts perfectly between a 22T and a 34T chainring (a 12T jump).
It's possible that Ibis meant that either the boost or non-boost crank won't work with the front derailleur. But once again that is confusing to me because as far as I know the only difference between a boost and non-boost front derailleur is the derailleur hanger. If I was going to run a 2x non-boost crank, I assume I would want a non-boost front derailleur hanger, and if I was going to run a 2x boost crank, I assume I would want a boost front derailleur hanger.
I really don't care who makes the crank, chainrings, or front derailleur--I just thought that with a 2x11, I could get a better chainline than a 1x11 system. For a 1x11, I would need to run a 30T-50 to get the equivalent low gear. (According to linkage design, the HD3 is optimal with a 36T chainring, but I have no hope of getting up steep climbs running a 36T chainring.). I also wanted to keep the option open of switching to a 1x11. With the Shimano crank, you can just ditch the small chain ring, but with the boost version of that crank, I think you are then stuck with a 53mm chainline.
I've been reading about chainlines, and some people say that a non-boost crank will provide a better chainline on a boost frame because moving the crank outboard worsens an already bad chainline situation, so if you refuse to move the chainring outboard in tandem with boost spacing, the chainline will actually improve. My goal is to be able to backpedal and not have my chain shift down a cog. Why? So I can restart on a steep climb by putting my pedals in the position I want without the chain shifting down a cog into a harder gear.
Can anyone recommend a 2x crank for me? Is it better to go with a Race Face Cinch system and buy the spider add on, so that I have more flexibility with manipulating the chainline with spacers and flipping chainrings? But then I've read that RF bottom brackets fail easily, or should that be considered the cost of greater flexibility? My current XT crankset and bottom bracket have taken a beating for 5 years, and I cannot tell any degradation of performance: there's no play, and I've pulled my cranks a couple of times and the grease has been clean as a whistle, but I don't ride in wet conditions.
