GT Stomper Prime 20
20K views 17 replies 6 participants last post by  tubby74
#1 ·
Any inputs on this particular model? Looking for a 20" bike for my 7yr old daughter. Is this ok or I can find something better? Thanks!
Key Features of GT Stomper Prime 20 Bike:
  • Sizes: 20" wheel / 6 Speeds
  • Frame: 20" GT Legit Fit Design, Alloy w/ Replaceable Hanger
  • Fork: GT Hi-Ten Steel, 1-1/8" Threadless Steerer
  • Chain: KMC Z50
  • Crank: Prowheel w/ Double Guard, 26T
  • Bottom Bracket: Cartridge Sealed
  • Pedals: GT BMX Flat Pedal, Resin
  • Front Derailleur: Shimano Tourney TX35
  • Rear Derailleur: Shimano Tourney TX35
  • Shifters: Shimano Revo Twist Shifter For Small Hands, SL-RS36 (Right Side Only)
  • Cog Set: Sunrace 6-Speed, 14-28T F/W
  • Rims: Alex Double Wall, w/ Machined Sidewall, 28H
  • Tires: 20 x 1.95"
  • Hubs: Alloy QR 28 Hole
  • Rear Hub: Freewheel
  • Spokes: 14G Stainless
  • Nipples: Brass
  • Brake: Alloy Linear Pull
  • Brake Levers: Tektro 3-Finger, Linear Pull
  • Handlebar: Steel 580mm width x 30mm rise
  • Stem: Alloy Ahead, 30mm
  • Grips: GT MTB
  • Headset: 1 1/8" Ahead
  • Saddle: GT MTB
  • Seat Post: Alloy Micro Adjust
  • Seat Clamp: Quick Release
  • 2018 Mode
#2 ·
No kids bike at this price point is perfect but I do like the Vitus better. HTA is slacker, wider gearing range and disk brakes. Disk brakes are a game changer for a kid going downhill. You can also get some really cheap hydros and put those on too. There are some flaws but I do think its a better bike. Shipping is free and will be in USA in about 5 days. It's worth checking out too.
Vitus
#3 ·
At least one listing I was able to find shows it as 26lbs, which seems pretty heavy for the price:
https://www.the-house.com/qgtstp20cb17zz-gt-bikes.html
At least around here, similar used Treks tend to go for around $50-100 on Facebook marketplace.
From your post a few months back, it sounded like she had a tall enough inseam that 24" bikes might be an option -- had you tried out any 24" bikes locally?
#11 ·
Some good but some really bad. Hard pass. Cranks are incredibly long. I know some 6-1 guys that run 165mm cranks. Downright dangerous on this bike, the cranks will hit stuff and the kid will crash. Fork might be ok? If its an airfork it might be. Hard to tell. Geo is getting long out back. Price is nice but hard pass due to the cost of fixing cranks and silly steep HTA 70d+ (also dangerous on hardtail).
#14 ·
Update: I got hands on with this GT Stomper Prime 20" bike last weekend. A buddy bought one for about 210$ from Level 9 (he got free shipping too somehow). Its a pretty little bike. I liked it a lot and there was some thought that when into it for sure too.
The thing that immediately jumped out to me, is that the frame and the fork both have bosses built out for disk brakes. Pretty sweet! The bars and seat aren't bad, tires are decent sized etc. Grip shift isn't my favorite but it worked enough. Cranks are nice length too iirc. It didn't have a bunch of BS like kickstand etc either. Sweet ride for the price point and you aren't forced into rim brakes if you could find some cheap 20" wheels and get some cheapo Tektro brakes off ebay.
#16 ·
Just picked up this bike for my 5 1/2 year old. The LBS had it originally marked at $269 but was having a labor day weekend sale and said he would sell it for $199. I couldn't pass it up. My guess is it's the 2018 model, which might explain the extreme mark down. I couldn't find one online for that cheap when I looked after I bought it. Plus, it's good to support the LBS in my opinion. So far he loves it. Turning that grip shift will take some getting used to though, as it requires a little hand strength. And my only other criticism, which probably applies to most bikes for little kids, is the size of the brake levers. They all seem to come with brake levers that are much too large relative to their hand size. He needs to use all 4 fingers to squeeze the lever. But overall, very impressed with the bike so far.
#17 ·
Forgot to ask, any idea what tire pressure to run? We went on a dirt path yesterday and he seemed to be bouncing all around. I know it's dependent on weight, maybe you can just list the rider weight with your tire pressure?
As an aside, has anyone converted this tire/rim combo to tubeless? The tires are kenda small block eights, and the rims are just some no name oem.
thanks!!
#18 ·
had this bike for my kid for about 14 months now, its a daily ride to school through every bump and trail feature he can find. only issue we've had was breaking a vbrake noodle which was a $5 part. you can go batty trying to find the perfect kids bike and I'm happy with this one and the kid loves it
