I'm thinking of going to a bigger disc on my shimano saints to a 223mm on the front! Has anyone had any brake rub issues with the 2mm thickness of the rotor? Are the pads any good?
That's what I was thinking with regards to the clearence,like you said once the pads wear in tolerance should be fine! Thanks for your thoughts!Galfer is a big time brake manufacturer for moto stuff as mentioned. I'd take them over random off brand stuff any day.
Also, SRAMs 220mm rotor, and trickstuffs 223mm rotors are also both 2.0mm thick vs standard 1.8mm that their 200/203mm rotors are.
It will work fine, just when the pads are fresh you might get more pad/rotor noise, or be slightly harder to center the rotor.
